WickedSVT
I was installing my WOT box Thursday and got the throttle, cruise, and crank wires hooked up but ran out of time to finish. I pulled my car back in the garage (it started up here).
Well yesterday I went to finish the ignition wires and here's where my problems started. First thing, the directions that came with it were for an 03/04 Cobra, no problem. I went off the directions on N2MB's website for 05/06. I cut the 2 red wires coming out of the the connector and spliced the red (of the red and black pair) to the connector side and the black to the harness side. Hooked up the ground and went to start my car.
My car wouldn't start, it would only keep turning over, but the WOT was working. One of my questions is am I in the right connector under the BEC box. Is it the connector closest to the strut tower? The directions never said which one.
Well I ended up cutting the wires and hooking the connector back to the harness so I could drive it. Any ideas what I did wrong?
Also I don't know if it's related but my auto up drivers side window won't work. I have to hold up on the switch to roll it up. When I open the door the window drops and when I shut it it won't go back up. I have to go to the passenger side and reach across to roll it up.
Thanks for any help
Thanks for any help
