Viperbluelx
When I bought my car about a month ago I only kept the factory 17's about a week before I put brand new 20x9 and 20x10's with brand new tires. Since then the steering wheel moves left and right starting around 40mph, especially when the cars cold. It does this from 40mph-up, all the way to around 70mph and then it goes away. Once the tires are hot it seems to be not nearly as noticeable. The tires are balanced and the car doesn't have a vibration, just the steering wheel shaking left and right on it's own. I pulled the tires/wheels and took off the rotor clips that people have issues with, also resurfaced all 4 rotors and replaced all the brake pads. I found that both the outer tie rod ends had play so I replaced them also. The shake in the steering wheel is still there and I don't know what else to do really.
