Oil Consumption? Anyone else burning a TON of oil?
Nastystang06
Mt. Pleasant, Tx
My car didn't burn oil the first 2500 miles
I put jlt intake
Lund 93 octane tune
offroad H and axelebacks
I have 3900 miles now and last night I smelled oil
got a friend to drive behind me and its smoking
Stopped pulled the oil cap off at idle and it was puffing
Bad blowby
Sooooo im gonna figure this thing out
wbt
I put jlt intake
Lund 93 octane tune
Bad blowby
Check your plugs to see which cylinder is having issues. If they look good, get a catch can.
Do you run 93 all the time with your tune?
Nastystang06
Mt. Pleasant, Tx
Yes I run 93 in everything I own
A catch can that fills up between oil changes wont do much justice unless your saying the rings need tome to seal off
Fallenauthority
La Plata, MD
Also tho I did change my oil at 2500 miles
Its non synthetic, because I didn't know the factory oil was semi
Would that make it burn?
No, it wouldn't burn more cause of being conventional. If you are seeing smoke out of the tailpipes I would check your plugs and see if #8 is drinking some oil
Sky Render
Stig's Retarded Cousin
NW of Baltimore, MD
+1, especially since you're running a tune.
Sent from my DROID2 Global using tapa-whatzit-thing
S
Stangs530
Guest
So I figured out why my car was using all the oil...
The PCV design on these cars are faulty and has absolutely no restriction. I pulled my intake manifold off and it was drenched in oil! The passenger side breather hose is allowing all the oil to be put into the intake and causing the smoke. The throttle body has no evidence of having oil pass through it which means that the drivers side head is not putting the oil into the intake, only the passenger.
A normal catch can will not cure the problem, it needs a catch can that will drain the accumulated oil back into the motor. I also think a redesigned PCV valve will greatly reduce oil consumption.
Fallenauthority
La Plata, MD
You won't get much if any oil from the drivers side line, iirc it is the vent line that runs to the intake tube, the passenger side is the actual pcv line. Oil drenched intake = lots of blowby
Sky Render
NW of Baltimore, MD
I'm going to have to disagree with your assessment. My car burns almost no oil.
Perhaps your PCV wasn't hooked up properly when you switched to the BOSS manifold?
S
Stangs530
Guest
Their is no way to not connect the PCV correctly, it connects directly to the manifold with the same hose as the stock and in the same location.
Sky Render
NW of Baltimore, MD
The valves design itself is faulty, I have checked several different of the 5.0's including a brand new valve and they are all identical.
Then why is your car burning so much oil, but others are not? Have you checked your #8 plug? What tune are you running?
