transmission fluid mt6
UnleashedBeast
Engine Lubrication Guru
Pensacola, Florida
Are manufacturers required to disclose this in a MSDS or product data sheet somewhere?
Unsure is they are required to do so, but the ones who have something to hide never do. They call it proprietary information, and leave it at that.
This is very misleading to the customer, especially those in the know. They do not want clear evidence they are using group III base stocks, yet still calling their product a "fully" synthetic.
Has there been any scientific testing on the synthetic lubricants based off group IV and V base stocks versus lubricants based off class III stocks?
Yes there has, but you better have your bull snot meter on when you read it. Everyone agrees that group IV and V are superior is all ways to a group III, except solvency. However, then they boast about how the overall package is the key, and not just the base stock. This is their way to say, we chose to use cheaper base stocks because our additive package makes up for the difference, and little difference would ever be known by the consumer.
This is mooOOOOOoolarky.
This is another reason why companies like Mobil 1, Castrol, and Pennzoil omit certain specifications on their product data sheets. There are a few specs that are a dead giveaway that a cheaper "refined petroleum" group III base stock is used in their formulation.
Delete the spec...hide the truth.
BlackMamba03
Iowa
This is another reason why companies like Mobil 1, Castrol, and Pennzoil omit certain specifications on their product data sheets. There are a few specs that are a dead giveaway that a cheaper "refined petroleum" group III base stock is used in their formulation. Delete the spec...hide the truth.
Are you saying it's not ok to use Mobil 1 75w90 gear oil in the MT-82? I know on the second page you said Amsoil MTG is rated at 14.8* on the cst @ 100*C scale. Mobil 1 is rated at 15.2* so it's a tad bit thicker. What other differences are there? I haven't read of anyone using Mobil 1 in the MT-82, I'm just curious.
UnleashedBeast
Pensacola, Florida
So 75w90 is whats in the mt82, no wonder it shifts notchy. What would happen if you used something much thinner? Syncromesh, synthetic atf, or synthetic motor oil?????
Unleashed no comment to my question about viscosity in the mt82?
Sorry, I missed this last time.
75W-90 GL-4 manual transmission gear oil was the original specification for the Getrag MT-82. The notchy feeling is caused more by a cheap base stock lubricant than the viscosity itself.
We used Amsoil MTG in a Grabber blue 5.0 yesterday, and the shifts are much improved.
Another car, we used Amsoil Synchromesh. That car also shifted well, but I believe the Synchromesh car had more gear roll over noise.
The TSB Ford fluid has a very low viscosity, about on par with ATF. A wide range of viscosity has been used in the Getrag so far. IMO, the best yet has either been true synthetic manual transmission fluids like MTL or MTG, or true synthetic Synchromesh type fluids.
I'm not saying it's not worth a try, but beware. Mobil 1 is notorious for using group III base stocks in their formulations, yet calling them "fully" synthetic.
They use a group III+ base stock that is proprietary to them, and it's called VISOM.
A natural evolution of the formulation
The Mobil 1 formulation strategy has always been based on selecting the best components available. We now have the very high quality Group III+ base stock, ‘Visom’ exclusively available to ExxonMobil. As we developed the Mobil 1 ESP technology we found that combining Visom with PAO could deliver a formulation of equivalent performance to an all PAO formulation.
Competitive advantage
Visom is the only non-PAO stock that can deliver the required performance to formulate a 0W grade oil that meets European OEM engine oil specifications. Visom is not available to our competition.
To support Mobil 1 growth
Global PAO capacity is limited. As we quickly approach this limit, new base stocks must be explored to ensure we can support the continued growth of the Mobil 1 family of products.
To ensure continuity of supply
As we saw with the 2005 hurricane, the more flexibility we have in our formulations, the better placed we are to withstand disruption to our supply. We can balance PAO and Visom supply fluctuations to ensure we can always deliver the final product to our customers.
To maintain market relevant pricing
As PAO supply has tightened globally, raw material costs have increased substantially. In the future, an exclusively PAO formulation may be priced out of the market or result in significant margin erosion.
To prepare for next generation basestocks (GTL)
Commencing 2010, the next generation of base stocks derived from Natural Gas (Gas To Liquids) will enter the market. These high quality basestocks will arrive in substantial quantities and will probably be used in the majority of competitive premium formulations. Visom is viewed as a precursor of GTL, and hence it’s use now in our flagship formulations eases our transition to a GTL world, and helps us understand how to maintain flagship performance using these high quality non-PAO basestocks.
Careful how you read their stock holder release babble above. This is Mobil 1's way to say..."Hey, we found a way to make more money, and our consumers will never know the difference." This document was more than likely meant for internal release only, but found it's way onto the internet at bobistheoilguy.com/forums.
For years many have asked what base stock Mobil 1 was using, but they would not say a word. Tight lips! You can't hide the truth forever. So those of you who support Mobil 1 thinking you are getting what you are paying for. Think again.
JAJ
Vancouver, BC
The EM document is interesting reading. It shows specific test results that demonstrate the claims of equivalency or superiority with VISOM and GTL combined with PAO compared to straight PAO products. They didn't hide anything.
UnleashedBeast
Pensacola, Florida
Want to talk about higher NOACK Volatility, slightly lower efficiency, and lower shear stability?
VISOM excels at those.
302
Atlanta GA
Just ordered amsoil MTG for my car today. When I get it in next week I'll report back with my results...
Rob72
No Japanese Mustang Here
Baltimore, Marxland
I'll be draining that Ford DCT garbage and replacing it with Amsoil the week after Christmas also.
Atlanta GA
x2... MTG, MTL, what to do what to do :giveup:
Well, the reason I am going with MTG is it is a little more viscous than MTL. I don't want gear whine. Granted I have some from installing the shifter, but a little is ok. I don't want a whole lot.
UnleashedBeast
Pensacola, Florida
Last weekend (Sunday), I did another car with Amsoil MTG. We added the Steeda Tri-Ax shifter at the same time. These two mods allowed the owner of a 2012 5.0 car to slam through the gears while grinding and missing gears is a thing of the past. A bit more interior noise from the high durometer bushing in the shifter, but no added noise from the new fluid. The owners first remark about the change was, "This is how the car should have driven from the factory. Huge improvement."
TheRookie65
NEWBIE
Aberdeen, NC
I currently have a Barton Shifter and Bracket sitting at the house waiting for my return home to install on my new 2012 5.0. So help me out here if you don't mind as I'm pretty much an idiot...LOL
1. Purchase 6 Month Membership
2. Order 3QTS of the MTG for the MT-82
3. Engine Oil? New Filter (type)
4. Diff Oil.... QTY and Type?
If I'm going to switch should I do everything?
Thanks for the help!!!
Rob72
Baltimore, Marxland
^I would go with the FRPP filter over the Wix filter that Amsoil sells. The Wix is smaller than the stock Motorcraft one that came with your car.
UnleashedBeast
Pensacola, Florida
Yes, definitely do everything for the best results.
1. Best way to buy at cost (YES)
2. Correct
3. Amsoil 10W-30 ATM and the EaO17 oil filter
4. Amsoil 75W-140 Sever Gear
