Rob72
No Japanese Mustang Here
Sam, you are the man again. This forum is lucky to have you.
They don't spin at the RPM the Coyotes do, so the hp loss at the top end isn't an issue.
Well, I'll get a picture or two in a few. But there's really not much to show.
The only visual differences are the eliminated squirters (bosses are still cast, just not machined out), and the smaller head bolts. The main caps are just slightly different. Aside from that, I don't see any other visual differences. It appears to be the same casting, but with some machining changes. Internally, the coolant and oil passages could be different, but it's nothing I can see without cutting it in half (Sorry, fat chance). The coolant passages around the cylinders appear the same, and the oil drain back/crankcase vent ports are all the same. Two of us compared the two blocks for 15 mins and only found those differences. Honestly, pictures aren't going to show anything. I'll get pics of the squirter bosses for reference though.
At any given RPM, the pistons in the 5.8 are moving MUCH faster than in the Coyote, because of the ridiculously long stroke in that motor.
I believe the windage losses caused by piston squirters increase as RPM increases, not as piston speed increases.
I believe that you're right. Also the GT500 probably has heavier pistons traveling at a faster speed giving it more momentum. Windage loss may not be as much with this motor.
All I know is that I want Darren to load a 93 race tune on his new car and stomp the shit out of it on a 100 degree day and let's see what happens.
The '13 GT500 will be running more boost pressure than any previous supercharged Ford. Keeping the pistons cool is very important. They don't spin at the RPM the Coyotes do, so the hp loss at the top end isn't an issue.
We don't know. Only an official answer from someone at Ford will be able to answer that. Piston squirters aren't a huge expense ... This IMO, is a durability change ...
This has been an interesting read that I have not been a part of until now. It's been like watching a propeller on a plane spin in some respects. You know, if you watch a propeller spin for long enough, it starts looking like it's going the other direction. 8)
Discussions about the removal of the oil squiters in a speculative way maybe having to do with the now infamous #8 issue as it may relate to some of the changes made to the Coyote and the redesign of the timing cover, etc.
There is a picture reference noted. back several pages, that shows the Coyote being run through it's paces with headers glowing that when I first saw it during the reading of the entire article, several months ago, was very familiar as I have done this on many of the newer vehicles of the past decade or so. So, it didn't strike me as being impressive to any extent. It just reminded me of how lean engines can run now-a-days.
Did you know that while they were testing this engine, they ran it for several minutes at WOT, shut the engine down then poured -20 degree ice water through it, started it back up then ran it to 225 degrees?*
*We witnessed another torture session where the engine was run at WOT for several minutes, the headers glowing just a hint of red, then the engine shut off and after several seconds of sitting, -20 degree ice water was forced through the cooling system. Frost formed on the test rig as the engine was about frozen to death, then the ice water stopped, the engine started and after a handful of seconds idling was taken back to max rpm, max load for another heat cycle up to 225 degrees. Each complete cycle takes about 10 minutes, and the engine must survive days of these non-stop thermal shocks.*
Those pictures you say at almost the beginning of this thread are part of the article below, if you care to read the whole thing from front to back. It is a good read that talks about the development and testing of the Coyote with interviews of the folks who engineered this engine. If you haven't read it, it just may answer a few of the questions you may have about, say, head design and coolant flow for example, among the other design features of this engine.
It gave me a better understanding of what this engine is made of and the devotion brought forth in it's development by it's engineers. Hope you find it just as enlightening! 8)
Read more: http://www.mustang50magazine.com/te...t_50_coyote_engine/viewall.html#ixzz1pdIv3pjm
You were suggesting a durability issue in your previous post. It would seem that you are suggesting that a coyote with squirters is a less durable design and the trinity with squirters is a more durable design.
I take it as a given that the coyote isn't designed to rev like the roadrunner. I am not suggesting making power by increasing RPM, but with FI and limiting RPM to <7000rpm. The 5.0 squirters should provide the same functional advantage as they do in the trinity. Granted the 5.0 doesn't have the pressure checks like the trinity, so there is more oil flying around at lower RPM, but is that really an issue? (Trinity has an oil cooler too ... my next addition.)
Maybe Ford rethought the piston because people were tuning the coyote to wrap-up like a roadrunner. If #8 position is the weakest link (due to - header design, water jacket design, etc.), it fails first when engine is overtaxed. A new piston, new basis for design (higher RPM) ... no need for squirters. Doesn't mean squirters are a bad thing, just not needed.
Here are some thread-relating sections of the 5.0 article for those who do not want to read it.
Benefits of the squirters are extensive. Testing shows the crankshaft runs 25 degrees cooler with them, and they help with octane sensitivity. Combined with the heads superior water-jacketing they are one reason the high-compression Coyote can feed on 87-octane gasoline.
So with the deleation of the piston coolers, will the 13's be required to run premium fuel only?
