Stock idler pulley and balancer bolts.....
Nasty GT
Using stuff to do things
Boone,IA
Been searching with no luck.
Sold the Procharger and need the stock idler pulley (2) and balancer bolt. I have stuff here in the garage that will "work" but I would prefer to put original stuff back on.
Short of going to the dealership on Monday is there an online source for these items?
Thanks in advance for any help.
Faron
Oh...and it's for an 07 GT.
Dealer for the harmonic balancer bolt. It's technically a one-use only item, I replaced my bolt when I spun my balancer and had to replace it last year.
Nasty GT
Boone,IA
Knew it was a 1 timer...just trying to avoid my local dealer at all costs.
I found one on Brenspeed so prob. goin that route.
Faron
AnotherS197GT
Serial Valve Dropper
Tampa, FL
FYI, you can use the stock crank bolt 2 or 3 times. I've reused mine with no issues and the directions for steeda udps also state it can be reused. If you are the second owner of the car and have no idea how many times it's been reused, just get a new one.
