Cleaning The Inside of Wheel
weather man
Persistance Is A Bitch
MN
O.K. did a search and found plenty about cleaning the finished outside of the wheel. The insides of mine are horrible and I think the inside of the wheel is just bare aluminum.
I found this product: Amazing Roll Off. Has anyone used this stuff. Is it dumb to pull the wheel off and clean? Mine haven't been cleaned for 20,000 miles and do not look good. Thanks for any feedback on what works guys.
BlackReign
Not dumb at all to pull the wheels to clean the inside. IMO it can make a detail go from nice to damn!
There is just a pretty big difference when the inside and outside of the wheels are cleaned.
Also, as I'm sure you know now, if you keep it maintained...keeping them clean isn't that hard or take much time.
HitandRunDriver
Amateur Goon
Orange, California
Here's my wheel cleaning routine
1. Wash Car
2. Drive a couple miles to strip rust off the rotors
3. Take off all 4 wheels
4. Pressure wash wheels
5. Clean wheels with Sonax Full Effect
6. Rinse off wheels and blow dry
7. Apply 1-2 coats of a wheel sealant (Poorboys Wheel Sealant or SmartWax RimWax)
8. Buff off and re-mount wheels
9 CG G6 on the tires
10. Done! ( For now)
I dust the faces and spokes off every couple days and reach into the inside to dust weekly. Black drifts show brake dust way too easily...
weather man
MN
I'm detecting a trend line here fella's!
weather man
MN
They work man. I like mine.
Definately gonna try the sonax. My wheels are really awful, so anything I do will make them look way better. I do laugh a little that I have a car worth pulling the wheels off to clean! lol
loots06
Monterey CA
I take off the wheels alls the time and clean the inside. Simple routine with just soap and water.
DRock
1. Wash Car
GET BREMBOS WITH AFTERMARKET PADS. DUST MORE THAN ANYTHING ELSE I HAVE EVER RUN!
BTW im still waiting to find you on the roads around here ha
Powered by Ford
+1! My brembos with stoptech pads definitely make a lot more dust than stock brakes with Hawk HPS's. Not a problem just need to clean it quite frequently.
DDTCM
Dan
Austin Tx
I can reach in and clean the inside of the wheels with every wash. I based my wheel choice on how easily I could get my hand in there to clean without taking them off.
Seer
Sonax full effect wheel cleaner, daytona speed brush
Then for maintenance, soap and water with a daytona speed brush
Seal them good after cleaning, makes maintenance a lot easier.
kylecm85
Lexington, KY
I'm with you on this one. I can reach in and clean mine every wash. But I might give that sealent a try.
