2008 Mustang GT Saleen Supercharged 18K Miles
mustang1200
Badass
For sale is my 2008 Ford Mustang GT 5 spd. The car is Vista Blue with Charcoal cloth interior with just over 18,000 miles. The car has been garage kept since I brought it home from the dealership and only seeing rain a hand full of times. The car came from the factory without a hood scoop and deck lid wing as the car was originally sent to Saleen from Ford to be converted to a numbered Saleen car. However Saleen sent them back with the promise of a free Saleen Supercharger to anyone who purchased them. The Saleen Supercharger was installed by an authorized Saleen dealer in Oklahoma and I took delivery shortly afterwards. The original engine threw several rods requiring a new short block with a host of upgrades list below. The car made 540rwhp and 550rwtq at Gear Heads while it was being tuned. The new engine and most of the parts were put in at 14,500 miles.
Asking $23,500 The car is located in Mckinney, TX
Mods:
Saleen Supercharger
JDM 302E Stroker Shortblock
Shelby Oil Pump with TSS Oil Pump Gears
JDM Sterling Custom Comp Cams
Comp Cam Valve Springs
Hardened Exhaust Valves
SPEC Stage 2 Clutch
SPEC Steel Flywheel
Kooks 1 ¾” Headers with Kooks Offroad X-Pipe
Magnaflow Catback Exhaust System
G.J. Joe 8 Rib Kit
Innovators West 10% Overdriven Crank Pulley
2.95” Blower Pulley
Thump RRR Tensioner
Saleen Ultimate Air Intake/MAF Kit
60lbs Fuel Injectors
JLT Oil Separator
GT-500 Fuel Pump Kit with Dual FPDM
AFCO GT500 Dual Pass Heat Exchanger w/Dual 10” Fans
Canton Battery Box Supercharger Coolant Tank (Powder Coated Crinkle Black)
Taylor Battery Relocation Kit (Trunk Mounted)
Speed of Sound Pillar Gauge Pod (Double)
Aeroforce Dual Interceptor Scan Gauge
Autometer Carbon Fiber Boost Gauge
Eibach Pro-Kit Spring Kit
WMS Hidden Hood Pin Kit
CDC Hood Strut Lift Kit
Powder Coated Stock Valve Covers (Crinkle Black)
Snow Performance Stage 2 MAF Meth Kit with Trunk Mount Reservoir (Car hasn’t been tuned for it)
Optional: 20” Boss 338 Wheels with Nitto Tires (Currently has stock wheels on it)
mustang1200
Badass
A couple of videos of the car after the engine swap.
mustang1200
Badass
The date says February 2nd on that Dyno?
I should have been more clear with the post. I finally got the dyno sheet. The tuning was done in February and this is a sheet from that session. They couldn't print it at that point because the printer was broken. I never concerned myself having the sheet until I put the car up for sale.
Sinner
Plano, Tx
I live in McKinney as well and if anyone who isn't local ill check it out for you, if needed.
