RED09GT
Equal Opportunity Offender
Think about it like pushing a filing cabinet.
If you push on a spot near the bottom of the filing cabinet (stock lower control arm position), your feet will slip and it won't move effectively (wheel spin)
If you push too high on the filing cabinet (this would be the lowest hole on the relocation bracket for a stock height car), it will tip over and not move efficiently unless you don't push too hard.
If you find the right spot (either the top or middle hole) The filing cabinet will move smoothly and efficiently.
I'm trying to remember where I ran across this in cyberspace but it makes sense.
