header install failing
Failborne
Pacific NW
I have a set of bbk lt's and I got the first header on and realized that the extension they gave do not hook up to my front o2 sensor connection. Is there a way to fix this. They fit the rear o2 sensors. Thanks in advance
Nuar
With long tubes, the front o2's should reach.
They are held with some clips up the wire, unclip them and they should reach from what I read.
killr3v
Hector G.
Katy, TX
Cut the little tabs off of the harness and they should clip on after that. I circled the tab
Scuba-Matt
Boost freak
SE Florida
You can make the stock wires and connector reach, You have to unclip the wire on the trans an pull it. Don't trust the 02 wire extenders they have failed and caused motor damage.
The 02 wire extenders that came with my Stainless works headers would plug in and hold but wouldn't make all the connections.
You can also order the SVT Raptor 02 sensors. They have longer wires and you won't need wire extenders or have to mess with trying to make the stock wires long enough.
Failborne
Pacific NW
Thanks for all the input looks like the driver side was zipped tied to the tranny I'm good now thanks for all the fast support
Napoleon85
Centerville, OH
Yeah Roush without cats is freaking loud
Obscenely loud ... I was able to tolerate it for a few months, but I ended up selling them and picking up GT500s. They're the best you can do with an offroad midpipe for the price point IMO. It does suck that so many people have the same setup though ...
