well done, I see you did it proper and didnt spray everything red lol like some caliper paint jobs Ive seen
Great job! I have been wanting to do this but I have not got around to it yet. I will probably use the brush on stuff when I finally do paint mine.
\Chris, I used the Duplicolor brush on paint when I did mine on the 07, and I can't recommend it enough! It was an easy job to do, I didn't have to remove the calipers to do a good job, and it still looked great when I traded it in after four years. And it was easy to give them a little touch up here and there every now and then.
Sorry, thread jack over.![]()
so you didnt even have to take the calipers off?
Well, I may have not been totally clear in my post. I unbolted the calipers from the brackets, but I didn't have to disconnect the brake lines. I took some old wire coat hangers to keep the calipers from hanging by the brake lines. I also removed the caliper brackets and painted those as well. One of the perks of using the brush on kit rather than the spray. You could probably do it wth the spray paint, but you'd run the risk of overspray.
