Faulty Axle Seals, anyone else?
phoenix335
MD
You! I know you! :beer:
I've had zero issues with mine leaking. It's odd that both seals let go at once, however. Maybe your rear axle was assembled on a Friday afternoon.
Yes you do.
Consider yourself lucky. This is what happens when you let Larry co-drive your car.:hammer:
Mach2burnout
05 Redfire GT
Central Louisiana
I remember that Seals-it having a weep hole in it to allow some oil, but not a lot of oil to move out to the axle bearing. Maybe it was a different one or maybe we drilled our own hole.
It's been a while since I used them. It seems like now that you mention it it does. Maybe it was the make shift ones that we put the oil between the two.
Sent from iPhone
