Guys with a DOB
Goody05
Omaha NE
Where did you guys mount that heat exchanger pump and how? if I can get some pictures that would help me out a lot thank you
GreenTerror
Rogers, AR
You would probably do better posting this to the dob site. I followed the Roush instructions and mounted driver side front bumper area. We fabbed up a bracket with rubber insert to make a mount.
obxdude018
Clayton, NC
If you are using the factory GT500 HE and the factory pump than it mounts on the HE. Here is where I mounted my meziere unit.
obxdude018
Clayton, NC
You need to email department of boost on the forum, they have a lot of spam on the forum and thats how he verifies you.
DiMora
More Is Better
Fayetteville, GA
It depends on what HEX and pump you are running. Variations can drive location to driver's side, passenger side, or front center (near horn) location.
If going hard-core...pay up and buy a Mezeire.
Do DOB's still howl or did it get fixed?
Powered by Ford
+1 we even have a tank in the works that mounts the Meziere pump to a tank that goes where the OEM battery goes.
No, the pan was updated to have a rib welded down the center to change its resonance frequency to address the issues some customers were having.
I am running the pan on my car and I do not hear the howl, BUT I also do not lug my car around at very low RPM...
We did compare the 2nd gen pan to the 1st gen pan in regards to noise, you can hear a slight difference between mine (2nd gen) and 908ssp (1st gen).
