6R80 transbrake you say?
CPRsm
Lol!
Apparently I hit a sensitive spot for you. Keep deflecting and talking in circles. It makes you look bad ass.
Let's see some timeslips and video you keep talking about. I would even be satisfied with some WOT launches at the track on the tbrake.
I know I have made the request numerous times in this thread alone.
Show us what you got.
Nobody's deflecting sweetheart. I quoted and aswered specifically, each worn out tired point you tried to make. I'm sure you can find a video if you try. Keep those internet haxor skillz sharp. But I'm sure you're in no hurry to post a vid of a car that has you covered by half a second and 6mph by the 1/8th.
I might be wrong but I don't recall you asking for a WOT pass once. I remember you posting danners brake holds WOT better, an incorrect wiring diagram of a brake w no line pressure raised, and a video to prove it didn't work. But I don't remember you actually being civil and just asking for one. Until you guys take the bet you won't get a video until someone just happens to be filming Chris like last time.
Maybe he should get Dustin to do it, he evidently knows some way to command the amount of airflow. That totally revolutionizes things! You don't need to waste money on things like heads, cams, headers, intakes, or even power adders, you just tell it to flow X amount of air and it does it!
It's understandable if you don't comprehend the terminology. Commanding airflow is what you tell the ecu you are moving in lbs/min. In the maf transfer function, that's how you richen the engine. You command more airflow so the duty cycle on the injectors is raised. Commanded is different than what is actually happening. Just like commanding a certain degree of timing and not getting because of other variables. Comanding airflow will not change the actual airflow. Like everything else in this ecu it's an expected calculation. Now all definitions and wording semantics aside, the long and short is in your tune you tell the ecu to expect 1200 horsepower worth or air on E85 because, like your brake, was hacked from the get go. And you had to command that much airflow so all 500hp wouldn't lean out. Now you know you've sent out logs, and to who. And you know I'm not making it up. Because I just might be able to post a log and show everyone your bark is louder than your bite.
That just opens up a whole new can of worms when expected airflow is that dicked up. Starting with the load tables. That's enough airflow to max out Ford's hard limit load of 3.0
Which means you had NO resolution in your load tables. Know what depends on load? Timing is one. Other is transmission shifting. Now with not resolution and such HUGE jump between cells I wonder how accurate shifting would be. I'd imagine it would be hard to acurately test multiple products and pinpoint a shifting problem when the tune is jacked from the get go. A tests results are only as accurate as the input.
Great job Dustin! Now if you'd go take some accounting classes, you could get better at other things too. Mrs. Danner is an accountant if you need any help!
Keep is classy bitch. Don't bring family into it. Especially laying another mans wife up for bait. You won't like my response, and I won't insult his wife out of spite for an internet degenerate. Try to keep your bouts of stupidity focused K?
JEWC_Motorsports
S197 Junkie
Psssstt Mrs. Danner is KDanner's wife lol. He was offering you her services.....not insulting her..
CPRsm
Oh duh. Skimmed too fast lol.
Bringing that up is asking for insults. It would be wiser to leave them out.
2012 2.9
I feel like this thread is just going to go around and around and around until everyone is in a nursing home and senile shaking canes at each other throwing their mashed potatoes around saying that their mashed potatoes had a better 60' and held to the spoon longer.
Right that's some funny shit he said you said he said I said you said he said blah blah blah very entertaining makes my day go by
Sent from my SPH-L710 using Tapatalk
trevnut
Nothing new from either side on this? Plenty of people patiently waiting for something to come out of all this.
wbt
I suppose it would be good to read a couple of pages back....
We posted results to include video and timeslips launching WOT on our version of the tbrake:
http://www.s197forum.com/forum/showpost.php?p=1944369&postcount=445
http://www.s197forum.com/forum/showpost.php?p=1944424&postcount=449
Dustin said he isn't going to post a WOT launch.
http://www.s197forum.com/forum/showpost.php?p=1945098&postcount=481
You can draw your own conclusions from that. :deadhorse:
CPRsm
YOU won't get one. Not until one of you takes the bet. I have nothing left to prove. Only two people in here don't think it holds.
CPRsm
Well I can have Chris make another video just showing the tach, and tell everyone it was WOT, too. Lol
wbt
Or you could man up and show the car launching at WOT off your tbrake at the track.
We did it with our "inferior" tbrake. Should be no problem for your's right?
Give people a reason to pay up for your version, not just some talk and hype.
CPRsm
The people paying for the brake don't doubt it. Only you two.
I didn't see proof of WOT anywhere. Just one vid of a tach and another launching. Doesn't prove it was WOT. Nice try though.
Or you could man up and take the bet.
wbt
WOT:
Very clear.
All you have is a bag of this:
ZBagoD
Show people what they are paying for, not a bunch of hype.
CPRsm
Again I don't see how those vids prove WOT. Hitting a two step and a launch doesn't prove WOT. You'd think for a free transbrake they'd be all over the place by now. Guess it's because more and more tuners are just refusing to max the line pressure. Does it upset you no one uses the free one and guys don't mind paying for my magic box? I mean you wasted all that time. All you accomplished was hacking together a brake no one can use, and helped me sell more kits and Tbrakes.
My customers are perfectly happy w their bag of dicks thank you. I offer a "no STD" guarantee w ea and ballz or their money back.
wbt
Doesn't disturb me at all. It's posted for people to do as they may. No money to be had by anyone.
If people don't believe this car launches at WOT on the tbrake I would be happy to show anyone in person. I will be at the track again next Friday, 1/31, for anyone interested. http://littleriverdragway.com/schedule/
I have nothing to hide. How about you?
What I find hilarious is why people would pay someone money for a box of parts and a tbrake that has run a best of 10.3. Hype sells. :highfive:
Come on....give someone a reason to buy your tbrake and let's see some WOT action.
