Just a tip, if that video was from a gopro, it looks like spot metering is turned off. That's why it's difficult to see outside of the car.... the outside is too bright.
Thanks! I've been wondering about that, will try turning that on next time.
Alright so...sorry no new pictures, but I have an "initial review" of the BMR spherical UCA and Steeda axle-side spherical bearing.
You've already seen the UCA:
And I bought this thing too after consultation with a couple folks:
The Good:
-I had been having some crazy rear axle hop when braking HARD, like "set-a-fast-time-don't-brake-until-you-see-God" braking, or really any stopping in autocross on race tires. This was worse in downhill braking zones, and worse the bigger/stickier the tires got. Now, I haven't done any "track style" 100+mph braking experiments yet, but, try as I might, I can no longer get the rear axle to hop around under braking, so that's cool.
-Acceleration is a lot more controlled. With the stock UCA, it felt like there was a garage-door spring wrapped around each axle tube connected to the chassis, like the rear suspension had to "load up" in order to go, especially between shifts. The poly LCA's helped this somewhat, but with the spherical UCA, it's cured pretty completely, so that's cool. VERY stable shifting, I can shift as fast as I want with just a tiny lift and the rear just stays planted.
-The "wind up like a rubber band and snap" thing is not present. I had previously run Brand X's poly-bushed UCA, and, when the car was laterally loaded up, say, in a sweeping turn, and then unloaded on corner-exit, especially if any power-on oversteer was induced, the rear would be really "snappy" and sudden in its unloading activities. It was so bad (especially in autox) that I re-installed the stock arm. I *may or may not* have hooned it up some on a couple OKC on ramps testing this behavior with the new arm...and the bind seems to be gone, so that's cool. It would probably be even better with some 302S LCA's...
The Bad:
-Holy shit is this combo loud. With two sphericals in the UCA, well, pretty much every noise made by the drivetrain gets piped right into the cabin. You can hear the diff working in turns, you can hear it unload when you coast, you can hear the axles turning away, gears meshing, lots of tire roar...etc etc etc. There isn't any "clunking" or any other sign of slop in the parts, just lots, and lots, of noise. I would think it wouldn't be nearly as bad if the stock axle-side rubber bushing was retained, but...go big or go home? Do NOT put the double-spherical setup on your daily-driven 'stang.Between these bearings, the MGW shifter mount, and the Whiteline bushing insert...well I might as well do some of those nearly-solid motor mounts just to give myself complete chassis-noise, right?
The Ugly:
-So...installing that Steeda bearing in the diff housing was...interesting. I took one look at it and said "fuck it" wrt doing the install in my garage with jackstands. I already didn't have the proper tools to get the correct amount of torque on the UCA bolts, and was getting that professionally installed, so I gave the bearing to Vorshlag for them to put on the car as well.
-You need to have some clever way to get the stock bushing out.
-You need to have some clever way to tighten the retaining ring on the Steeda bearing. It's a 58mm hex ring...so you probably don't have that socket. With the axle on the car, there's no room to swing a big wrench to tighten it, and the bearing is too close to the pumpkin for a socket to fit over the ring. I think the guys @Vorshlag ended up putting a 58mm socket on a lathe and machining it down until the walls were thin enough to go on the damn thing, so...yeah. Glad I didn't do that in my garage.
-All totalled, plan on ~$1000 to get this setup on your car, or plan on $600 and a royal PITA self-install, and hope you have a lift and metalworking capabilities.
Other updates:
I also finally got my passenger seat done (Cobra Monaco) so there will be pictures of that up soon.
Next action: Sunday, autocross in Tulsa. Rain in forecast. I may be able to finally put a "Rivals in the wet" review on the internet for the (seemingly) large number of people interested in that. There are dozens of us. DOZENS. I'll also get to try out my aim solo, so that's cool.
My XP16's are worn out, and I ordered XP24's as replacements. Hopefully they're in in time for a track day @Hallet later this month.
How did you like your xp16s? I have XP12/10s and they're great so far. I wouldn't mind trying 16/20/24s but I don't know why I'd change what I have (I won't be on slicks).
Also, it's good to hear that the harmonic axle damper thingies helped cut some noise transmitted into the cabin. Makes you wonder if a bigger/rubberier one would work better
The 16's were fine. Lots of dust...but...race pads. They lasted 5 days and are now gone. Mind you, three of these days were at Eagle's Canyon, which is a pretty brake-intensive track, and I ran probably 7 hours there. It's been recommended that I try the 24's, so they're on order now.
I consider 5 days of hard track driving pretty good. If the 24s do better, that's impressive. Do you change to a different pad when you drive the car on the street?
CSamsh, have you been able to mount a gopro on the lower grille? Mine blew back and aimed to the sky after it got wind speed.
Did you damage anything when you went off?
Simmons
