Spent a lot of time with some Cobra Jets lately, I've seen every part in them, under them, you name it. Not storebought CJs that some collector buys to look at or maybe makes a few hits in some kind of bush league racing, these are cars built from what were originally street cars and actually get raced in NHRA competition by guys who have even done things like win the US Nationals. The rear supension was interesting, different than what is typically seen. NA cars with the 2010 352 pushrod and the 2010 4.6 3V combos, run middle tens and 60' in the 1.30s, couple of footbrake auto cars and one was a stick car. That's not all out, they still have performance left in the bank. Every car I've seen had an upper control arm that was a foot long center to center, the front pivot point being right by the big bolt that is under the rear seat normally. The lowers were only dropped down by the amount the OEM anti roll like came on the store bought CJs does, little more than an inch, way less than the aftermarket brackets do. And these cars were low, way low, like slammed low with no bumpstops at all. What has become accepted as the norm for S197 suspension would tell you they would never work, but a mid ten car that 60 foots that quick on a soft tuneup obviously does work very well.
What I'm getting at here is don't just run with the pack and copy what someone else has. Test, make some parts of your own, test some more. You'll never be faster than the other guy if you just run the same stuff he does. There's a TT coyote car in NC running really good right now with homebuilt suspension parts, engine, and trans, another good example of working to figure out what his own car wants, not just copying some other guy.
