New\Used takeoff parts
Rob@Evolution
Aston PA
BODY:
-New Classic Design Concepts Smooth C-Pillar Scoops P# 110041...$100.00
Fits 05-08 Retails @ $157.00
-Stainless Steel Tow rings... $75.00set
Fits 05-10 Super Duty
-New Vertical Door Kit...$1100.00
Fits 05-14 Mustangs
-O.E Trunk Panel for a 13-14 Mustang GT...$50.00 2o\h
COOLING:
-New Flex-A-Lite Electric Fan. P#394 ... $100.00
-New Ford Racing Trans Cooler Scoop. P# M-5025-MBR ...$75.00
Fits 2011-2012 Mustang GT with manual transmission
-B&M Oil\Tranny Cooler P#-70266...$80.00
DRIVETRAIN:
-Race Only 8.8 Spool Rear w\ welded houseing, Strange axles & brakes, 35 spline,
Solid upper mount, 3.15 gears...$1,800.00 ( Has only 15 passes on
it.)
ENGINE:
-FORD ignition coils 2C6U-12A366-AA (8)...$60.00set
-Ford Racing Coil Covers •2011-14 Mustang GT 5.0L 4V 'Ti-VCT'...$60.00..Shipped
•POWERED BY FORD Logo
•Plastic
•Gray Finish
-MSD Blaster Coil P#82438...$200.00 (New in box)
Fits 05-10 GT
-Evolution Oil Filter Relocation block for a Mod Motor...$100.00
-New Fore Precision Works Shelby Fuel Rails..$150.00
Fits 07-14 GT500
-Cometic 5.4L DOHC 4V Head Gasket set...$200.00
93mm bore .036" MLS
-Like new Stock Supercharger W\ 2.6 pulley. P#6F066 ....$800.00
Fits 11-12 GT500 Retails @ 2373.35 only has 2200mi on her
INDUCTION:
-10lb NOS tank...$125.00
-Used Ford Racing Throttle Body 90MM ETB 5.0L Mustang P# M-9926-M5090...$300.00
-New Kenne Bell Polished MAF Housing...$100.00
-New turbo X Racing bypass valve Type H-34...$100.00
SUSPENSION:
-Used QA1 303 Double Adjustable Shock. P#TD303 ...$200.00set (2 sets)
Fits all 05-14 Mustangs...Retails @ $267.95ea
_
-Slightly Used Steeda Race Only Lower Control Arms Part # 555-4417 ..$150.00
Fits 05-14 Mustangs
-Slightly Used BMR Upper Panhard Rod Support Part # PHR007 ...$50.00
Fits 05-14 Mustangs
-Evolution UCA Race Only...$100.00
Fits- all models 11-14
TIRES:
Used Drag Tires
-Part # 3055W - M/T ET Drag Slick 28X10.5X15W - 2 Available - $100.00ea
-Part # 3055S - M/T ET Drag Slick 28X10.5X15S - 2 Available - $100.00ea
-Part # MHR-050 - M&H Drag Slick 28X10.5X15 - 2 Available - $100.00ea
Slightly Used Drag Tires
-Part # 18214 - Hoosier Slick Radial 30X10.5X15 - 2 Available - $150.00ea
Slightly Used Radial Tires
-BFGoodrich G-Force T/A KDW2 255/35/20 - 2 Available - $120.00ea
-BFGoodrich G-Force T/A KDW2 285/30/20 - 4 Available - $120.00ea
Brand New Front Runners
-Part # 2991 - Goodyear Eagle 25X4.5X15 - 2 Available - $160.00ea
Brand New Specialties
-Part # 6626 - M/T Sportsman S/R 31x18X20 LT - 2 Available - $400.00ea
-Part # 6682 - M/T Sportsman S/R 26X6X18 LT - 2 Available - $160.00ea
Any Questions let me know.
strictly180
by any chance do you guys have front lower control arm for the driver side?? thanx
