01yellerCobra
When I broke mine in I let it come up to temp then hit it a couple times with full boost. The engine turned 100 miles while on the dyno.
Sorry to hear this Jason. I am not a fan of SS rings because they are so hard to get seated correctly. As stated, you have an extremely narrow window to have them seat and if you don't get it right the will never seat.
Yea I almost wish I had just bought the 326 stroker from Brenspeed or the 5.0 stroker from Ford. There are so many people that have gotten them to work though. Sucks that it had to happen to me. I thought I was doing myself a favor by not skimping out on anything.....wroonggg!
when you say totally rebuilt you mean new everything or just got resized pistons and rebalanced with a rebore?
It was my understanding that SS rings were best at holding boost when pushing past about 14 psi??
What other type of rings are there that are more forgiving when seating?
Yea at this point, I think I'm just going to drive it on low boost and enjoy it while I can. I'll keep an eye on everything and I'll probably send the oil that is in there now off to blackstone and see what they say.
You built your most recent motor right?
Bruce I understand what you are saying, but as far as my motor is concerned I was after building a real stout motor that could hold power, not necessarily a race motor per say. So I guess I'm not sure what I did to not be the best choice. I don't see what having SS rings would hurt. I guess in my case it was just a combination of things that caused it to fail, not necessarily the parts fault.
What do you consider high boost? When I spoke with Diamond abouty goals they suggested the AP SS ring. Which I haven't had a problem with. But I didn't break them in easy.
I didn't mean for that to sound like an attack. I was genuinely curious what you consider high boost.Me? I go by what has worked for people. I've seen motors up to 25psi without ss rings do just fine.
I'm not Diamond. Just a guy on a forum. And I didn't say that everyone will have an issue with ss. What I'm getting at is if there is a break in problem it always involves ss rings.
