Hi Everyone,
So I installed a Roush CAI and a 93 race tune from BAMA. After a couple WOT pulls I noticed it was making a noise. While at WOT I would hear a metal rattling noise in the Mid - High RPM range. Is this pinging? I believe it is from what I have read. Anyway I switched to my BAMA Performance 87 tune. Did a couple WOT pulls with it. I thought the noise was completely gone but after the 3rd or so pull I noticed a rattle but it was a lot less loud than the original Pinging and only rattles for a split second and does it at around 3000 RPM and again at around 4000 rpm for only a split second and under medium load not just WOT, where as with the 93 tune, it would rattle much louder and for longer and at WOT only (I think only at WOT). The rattle with the 87 tune sounds maybe a tiny bit different where as with the 93 tune it sounded like marbles in a tin can vibrating. It doesn't rattle long enough with the 87 tune for me to really be able to say what it sounds like, but I can say their is a bit of noise at those mentioned RPMs. Do you guys think the slight noise I'm hearing with the 87 tune is also pinging or something else? I parked the car for now as I'm afraid to drive it. Do you think my issue is with the tune, or bad gas? I'm going to call BAMA tomorrow and see what they say. Also do you think I damaged my engine in any way? I did not know what pinging sounded like until after a couple WOT pulls with the 93 tune. I'd say < 10 pulls and driven normally 100 or so miles. I honestly thought I didn't install the intake right and that was causing the rattling. I'm going to install the venturi tube in my Roush CAI and load the stock tune back tomorrow and see if their is any noise at all. Unfortunately I don't have any time to do that today. Any help is greatly appreciated.
