BIGGZ
Just got this 2010 GT that already has a JLT CAI, MBRP axle-back exhaust, and the mid cat/s cut out and normal pipe welded in. Also came with a BAMA SCT tuner in which he only had a 93 "PERF" tune and a 93 "RACE" tune. The only tune that runs decent is the 93 perf, but what confused me is when i tried to return the car to stock tuning it started running terribly. Which doesn't really make sense to me because its not like the car has cams or anything crazy so I would assume the default ECU tune would do just fine. In any case on the tune that runs decent I've noticed the RPMs normally idle at 1000 but now at idle the car struggles to maintain a consistent idle, usually bouncing from 950 to 900 RPM every few seconds. The car also constantly backfires lightly, even under 2000 rpms im always hearing burbles. Changed spark plugs, haven't tried coils yet as they looked good when i changed the plugs. Didn't fix the issue so i took off the throttle body, cleaned it, cleaned the MAF sensor and put it all back on but the weird fluctuating idle remains. Currently thinking either vacuum lines or a tuning issue but wanted input here before spending too much more money on false fixes. I've also noticed rarely when pushing the clutch in on decel my lights will flicker like there losing power. Not sure if its relevant just wanted to include all details I could.
