Leather Seat Covers
JC SSP
FL
My 05' GT factory seats w/125K+ had some rips in the lower sections but the rest of the seats were in great shape. I am a stickler for nice cars (interior & exterior), so have been considering and looking for seat options. I have a set of Recaro's that I could have installed but they are cloth & want those for another project.
Shopping around most local upholstery shops wanted $2k+ to re-cover the factory seats. Online searches had leather (real or faux/fake) seat covers from $400-1,600+. I love Ebay (yes, I know flea bay). I saw a USA vendor with excellent reviews and the with holiday discount got the real leather seats for $475.00. When I called the vendor to confirm the full set includes headrest, they quickly said NO and that the seats are OEM replacement which means leather and vinyl is used in some areas. OK, so paid an additional $90.00 for real leather headrest. So, I am in for $565.00 plus $20.00 for hog-ring pliers from Amazon.
Vendor: https://autoseatreplacement.com/
Ebay info: https://www.ebay.com/itm/226737908136?var=525903991844
Seats arrived within a week, and the vendor even included a bag of hog-ring staples. The seat covers have that smell of real leather and are supple and easy to see what parts fine grain leather are and what are vinyl sections. I am pleased with the purchase and decided to install the day after Christmas.
I tackled this project with my lovely & patient wife. It "kicked both of our ASS!" This is a "2-man job" not being sexist, but my wife is 5' 99lbs (my pit bull weighs as much) and we struggled getting the covers on/off. I am a big strong guy, 6'2" 200lb but fought pushing & pulling the seats covers and moving & turning the awkward seats to accommodate different positions. The passenger seat took us about 2-hours, so we decided to do the drivers which took us a long 4 hours due to reinstalling the hog-rings which was virtually impossible on that seat. Also, the driver seat is power, so heavier than the passenger seat and by this time the sun was overhead, and we had to relocate to inside the garage.
I watched this installation video online:
I was lucky that my foam was in great shape, so I didn't have to steam them. Also, only on the driver seat did the Velcro on the lower section start to peel up. Simple 3M adhesive and it was glued back in place. The lower seat covers were easily identifiable Driver & Passenger, but the uppers seem to be universal. The covers are 90% replicas of the OEM Ford and came with the perforated inserts, but some of the mounting tabs and pockets are not stitched in as the OEMs. The uppers do not have cut-outs for the headrest or the seat recliners. Not an issue, I used an awl to find the center and then exacto-knife to cut a small square, trim with small scissors and the leather stretches around the clips. On the recline lever, I used a black sharpie to draw a vertical line where the channel is and then the exacto-knife to cut a small slit (about 3"). From there I could see how much I had to trim in order for the plastic cover to go in place. There are some other areas where you need to modify, use your own push-pins to secure the hanging leather pieces, but not an issue. I did have to do some plastic repair on the driver side power side panel. The Christmas tree clips (I have no idea why they are called this) they should be called "destruction clips" because they chew up the factory plastic making the trim panel loose and not sit flush with the seat. I used a 2-part plastic epoxy to fix the broken plastic clips. I have used this stuff on M4 handguard and have held up well in that environment. LOL
Another tip, leaving the new leather covers outside in the sunlight to make it pliable. Also, on the hog-ring pliers get the ones which are spring loaded, they hold the staple in place while you align it with the cover and seat retention cable. A trim push-pin clip removing/pry tool is a must as are different plastic pry bars (interior trim removal tool) so you can hold down fabric while installing hog-rings.
I am very pleased with the outcome, and the interior looks better than factory. We also shampooed the carpet since the seats were out. Now I need to do my timing chains, tensioners, etc. in the next few months. LOL
IMG_4793.jpgIMG_4795.jpgIMG_4797.jpgIMG_4800.jpgIMG_4801.jpgIMG_4802.jpgIMG_4805.jpgIMG_4806.jpgIMG_4810.jpg
StockishS197
Houston
Great write up! Been looking into something similar for mine, but mostly because the driver side lumbar is broken on mine. Is that something that is an easy side project when doing this?
JC SSP
FL
It would still be a 2-man job since you have to remove and reinstall the cover to access the lumbar assembly. It can be done but consider have everything ready to do the repair efficiently.
kazman59
King of Kazmania
Kazmania
Came out nice, looks great!
I wrestled the Recaros by myself on the carpet in the living room, feel I can get more leverage. Learned that a long time ago, as I've done multiple sets of seats over the years.
MADGT
USA
Wow, they look really good. Yes, in Northenrn Virginia they also charge around $2K plus for the work. I am not sure I have the patience to tackle this problem...but glad you did and shared with us.
DFV1
USA
Very nice job. Should give your 'stang many years of service. A couple of questions:
Are your seats airbag equipped? Do the leather seat covers work with airbag equipped seats?
JC SSP
FL
Thanks buddy.
No I have the base interior but I do believe they offer Air bag options seat covers.
crjackson
Midgard
It’s a big job and you did well. I’m too old, lazy, and have no help. So I paid a local custom shop for some custom made front/rear (including head rests) 100% leather seat covers. Also included some foam replacement, heaters repaired, and lower seat plastic trim was replaced. With custom red stitching, it turned out great. You paid W A Y less than I did, and had a great outcome. Kudos!!
healy1963
You an excellent job. Have a 05 but with gray seats & cant find a drivers side bottom anywhere. My seats are strange that the fronts have a perforation that is a dash (-), straight line. My backs have the diamond shape. Manufacture date was March 05.
ryunker
Madison, SD
View attachment 113037View attachment 113038View attachment 113039View attachment 113040View attachment 113041View attachment 113042View attachment 113043View attachment 113044View attachment 113046
bigmace
Oregon
Quick question for you OP? Would you say the new covers match the old factory ones pretty well? My 07 GT seats are in pretty good shape overall but the drivers seat bottom has some minor rips. I see that I can just buy the bottom from the seller. I already partially dissembled the seats to replace my failed seat heater elements and broken drivers lumbar support so not to daunting off a task. I do see that it looks like its missing the carpet like material on the sides that you see on the factory.
Anyways yours look great, nice upgrade for sure!
JC SSP
FL
They are close but not exact copies. I personally think they are better than OEM. If you do replace the lower what you will clearly see is new vs old and not much more than that, since pattern & design is almost the same.
pass1over
I like it LOW
Trenton, FL
pretty sure that's where I bought the seat cover for my car as well, same vendor. I've been super pleased with it. Had them in the car for over 3 years and they still look like the day I put them in. I did the driver side only and you can't tell the difference between them in the car. Color, pattern, etc, is all spot on.
royjj12
Delaware
You did a great job. My tops were okay, but the bottoms were showing signs of wear. I explored my options, and they were all too expensive. I even looked for some recycled seats, but had no luck. The trade-in value for my car with the mileage is less than $2,000. I couldn't justify paying almost that for seat covers. I finally decided to cover the bottoms, at $50 for a pair of cushions on Amazon.
