Miss not throwing codes.
JC SSP
FL
Is this a new issue? Could be bad gasoline?
Connect a scanner with datalog capabilities and drive it to record the event.
StockishS197
Houston
You would need to scan for misfires to identify it if you want to target the specific cylinder.
To trigger a CEL, it has to trigger enough misfires per 1000 revolutions so it may be under threshold.
If you cannot use a datalogging software, start with the basics - pull coils, plugs and look for any inconsistent cylinders and replace any worn parts.
the sandman
Crystal michigan
Brother Juice; I didnt know they could be turned off. Brother JC; yes its new but doubt its gas as its a intermittant miss. Like one cylinder. Brother Stockish; Can I data log with my SCT x4? Is there instructions? Planning on keeping car as long as I can drive. Plugs have less than 5k but coils are unknown age.
JC SSP
FL
SCT X4 does have datalog capabilities but as I recently found out… mine needed updating and 5,000+ files prevented me from doing it over WiFi. Last time I used it was over 5 years ago when I uploaded the tune. SCT was no help and doesn’t have live assistance or even a phone number to call and speak with a representative.
Juice
Yes, it can be turned off. Some tuners do it for cams.
If you actually have a miss, pull sparkplugs. One (or more) will look different from the others if there is a miss.
the sandman
Crystal michigan
Thanks for all the help. I dont think monitors are turned off as it has thrown codes in past. If it is a coil it will get worse. I will see if I can check header temps for a cooler cylinder. Im learning but the computer side will always be a stumbling block. I do need to learn to data log. Any suggestions? I too am disappointed with SCT,s lack of customer service.
86GT351
Sunny South Florida
Actually a scanner with Mode 6 capabilities should show these events if it is truley a misfire. Is the car in question an Auto or Manual?
whitmanink
denver pa
if i were you id get it fixed by replacing all the cop with ford ones , (unless you have a good coil tester. but they are prolly starting to go out )
and replace all the spark plugs,
that will give you the best choice for success ,and if it still does it (which im pretty sure it will),
you will be alot better off trouble shooting
MasterofDisaster
Michigan
A couple years ago, I thought I had a small occasional, intermittent miss. No CEL and no codes. Changed the plugs, but still had this vague unsettling problem. No CEL/codes. Tried fuel injector cleaner. Even changed the coils, but still not change and no codes. About a week later the CEL came on with a code for a misfire. The fuel injectors were clearly working normally, so I took it to a shop. Their analyzer said it was my PCM. Took almost two weeks to get a new computer, but it definitely fixed the problem. No problems since.
I still think I did the right thing by trying the simple, cheap things first.
