18x10.5 or 18x11 wheel options?
05yellowgt
Dayton, OH
I'm looking for a non drag wheel option for my car. I want to run either the 325/40/18 M&H Drag radial or the Nitto 555r 305/40/18 drag radial. That means I need something in the range of a 10.5 or 11 inch wheel. I'm having trouble finding wheels in that size. What have you guys found out there?
Freaknazty
KEYBOARD NINJA
SOUTH LOUISIANA
they make a cheap bullet wheel on ebay thats 10.5" wide other than that your going to have to go with a ccw or boze forged ....something to that extent and your probably looking at 800-1k each
05yellowgt
Dayton, OH
I know about Welcraft, its just that the finish on my AFS mach1 rims isn't looking to hot these days. I was thinking if there was a semi-affordable set of 18x10.5 or 18x11 rims I would go that route but it looks like it will be expensive either way.
_M_
Nashville
youre gonna have to go CCW like me and spend the $$$
there is no 10.5 inch wheel out there. Ive ordered 2 wheels that where supposed to be 10.5 and they both measured 10". after calls to both companies (rev wheel and i forget the other one) they said oh yeah its a typo...but they never correct it and never offer any refund for false advertising.
Im going with CCW
DusterRT
Defected to Deutsche
Seattle, the Sunshine City
Finish as in the paint or the work/welding? Any pics? I'm very close to sending them my wheels and I'd like to see & hear about this..
Thinkkker
Spring, TX
Enkei NTs03+M
35mm offset which is great for the fronts. about a 55 in the rear though would be better.
s197shockwave
I have saleen 18x10s in the rear with the 99-04 offset(24mm), and i have a good 2 1/2 inches of clearance on the inside of the rear wheels. I have thought of widening them, but i have heard some horror stories about being able to balance the wheels correctly after the widening.
I keep thinking i could go 18x12 though.
05yellowgt
Dayton, OH
Finish as in the finish on the wheels; the clear coat is pitting on some of the aluminum below is starting to corrode. Nothing to do with Weldcraft or their work. Everything I have heard about them is that they do tremendous work.
