Moroso/Canton Replacment Tanks
scramblr
New Braunfels, Texas
I have the Moroso radiator and p/s tanks along with the fuse box and brake reservoir covers. They all fit well except for the fuse box. I had to use my dremel on the cover to make a little room, but after that it fit great. The p/s tank cap has a vent hole on it and it gets moist with p/s fluid. I have to wipe it off about once per week. Not much, just annoying. Overall I'm very pleased with these parts.
doogie
SE WI
I have both the brake & fuse box covers as well and did not have the same issue with the fuse box. It fits so snug that removing the assembled pieces is almost impossible, so I will need to do the same thing with a dremel fairly soon.
Now I just need to get the 2 reservoirs and plan to call BBR to see what kind of deal they are offering :thumb:
NastyStang113
Made in U.S.A.
Central Florida
What kind of deal can we get going on?
What exactly did you have to dremel with the fuse box cover?
The coolant overflow tank fits great..The power steering tank does not at all. ANyone had any fitment issues with the power steering tank? Before I send it back, I wanted anyone's feedback..thanks..Dont mean to threadjack, but its info you should know..
Do you have the Moroso or Canton? Sounds like all of the power steering tanks don't fit perfectly.
Steedman07
Classified's Moderator:)
Connecticut
If you guys have either a Vortech or a Procharger, the power steering tank gets moved to the other side of the car, and, the Moroso power steering tank will not fit. Me and my mechanic were playing with it for a while trying to get the Moroso tank to fit, and its not going to happen..Just an FYI for ya..So I am trading it in for a fuse box cover and a brake fluid tank cover..Thanks to Bill @ Moroso for working with me..
scramblr
I'm on dial-up, so not going to mess with uploading a pic. But did Google these.
This is a pic of how the stock fuse box cover snaps into the Moroso cover. The bottom right of the pic is where the cover slides next to the PCM. I had to cut about 1/2" wide by 1" long piece so it would slide down next to the PCM. I like using my Dremel, so no big deal.
This pic does not show the correct side either, but it's the front right corner next to the PCM. Even if I knew I had to cut that piece, I would have still bought the cover. Looks really good IMO.
doogie
SE WI
How funny... those pics are from my car!!
I was actually trying find where I posted them!
My cover actually went on without any modifying like you described. But as I mentioned previously, when installed it fits super tight (which is probably not a bad thing). I have a few more pics I can post up if you need them.
scramblr
LOL...too funny. I Googled it and found them on MustangForums.
EagleStroker
N/A Junkie
Memphis, TN
It's a shame I just got some Canton tanks cheap, those Moroso fuse box covers are sexy but I can't have conflicting logos going on in the engine bay.
Boozshey
Tampa
Unless they are paying me to keep it that way, I don't give a damn... :thumb:
Steedman07
Connecticut
The Moroso power steering tank wouldnt fit cuz the Vortech, so I traded it for a Moroso Fuse box cover and a brake fluid cover:clap:
