Will these fit? Thanks guys!
KITT
Sell it!
JC TN
Will these wheels fit my 08GT? Im just intersted in the rear right now!
Thanks guys!!! Found this in the sticky thanks to Chris06GT and MexGT.
JEGS SPORT STAR CAST WHEELS
Front : 15x4 W/ 1.75 BS , PN: 555-67051 , 3/8" Spacer ,PN: 555-65051
Rear : 15x8 W/ 5.5 BS , PN: 555-67077 ,NO Spacers , NO Relocated Swaybar , both front and rear use factory length studs and stock conical style lugnuts.
Has anyone used these wheels with no clearance issuse? Thanks again!!!!!!!
Chris06GT
Dragging LS A..
Alabama
NO, they will not fit!!!
Read the fitment specs in the sticky......You will need a 7.5" backspace on a 15x10 to fit the rear......and it takes a lot of grinding....
MexGT
Mexico
none of them will fit.
1.- You need bolt circle 5x4.5 ONLY.
and once you cover that you need ...
2.- 7.5" BS on a 15x10 wheel.
and maybe this one will, since its a 15x8 a 5.5" BS should work
JEGS #555-67077
KITT
Sell it!
JC TN
JEGS #555-67077
Has anyone used these wheels with no clearance issuse? Thanks again!!!!!!! Interested in the rear only right now!
Chris06GT
Dragging LS A..
Alabama
so which of those type wheels will fit i am shopping for some, also which tires do yall recamend a drag radial, et tire, or full slick. and what size also. thanks
Again, not trying to be a dick here, but all the info is listed in the sticky...what wheel fits, what size, backspace, etc that is needed...:hi:
KITT
Sell it!
JC TN
Thanks man I see the sticky now.
Original post changed I assume those have been used successfully?
Chris06GT
Dragging LS A..
Alabama
Yes sir!! A few guys on here I believe are running those Jeg's wheels with no issue's.....Maybe just a little touch of grinding on the rear and the 3/8" spacers on front with no issue's...
