TSW STRIP wheelS
bullitt2086
Im in the market for some wheels and im intrersted in the TSW Strip wheels in black. I found the 18x8.5 in a 20mm offset for the fronts and 18x9.5 with a 45mm offset for the rears.
Will i have any problems with these offsets.... will they sit flush with the edge of the fenders?
can i see a pic from someone with these offsets please? THANKS
blk5.0
these are not 18s but they are 20s and they fit flush on the rear with 295 wide tire
blk5.0
on the offset im not sure. all i did was go to discount tire and buy them and what ever offset they gave me works great. i like the invos.
peetiewonder
Terminator
SFV, CA
45 offset will be kinda sunk... i'm running 29 offset with a 9.5 rear on a 275 tire and that is FLUUUUUUUUUUUUSSSSSHHHH
Jucostud
booooost'd
North of Dallas
If you are planning on doing a bbk than 20 in the front is what you need. If not, than do the 45 or whatever it is in the front. They make both offsets. But the one that sinks in more won't clear a bbk. 45 in the back is perfect.
Kona6Stang10
Let me clarify, in case the OP doesn't know what "BBK" means.
BBK= Big Brake Kit
bullitt2086
I shouldn't rub with a 295 in the rear on eibach sportlines right? I plan on doing the 18 inch wheels
bullitt2086
yea but wats the offset on your wheels? dosnt that play a fctor on if it rubs the fender or not?
