dino
'03 Mach 1 automatic drivetrain. less than 10k miles. motor, trans, comp, harness. complete swap. - $2,999 OBO
http://images1.snapfish.com/232323232fp:;3>nu=3396>872>964>WSNRCG=343:3;3:8:335nu0mrj
Aluminator shortblock(lower compression version), needs one piston replaced(damaged ring land) - 1500
complete Windsor PI heads(loaded w/ cams/valve train, w/ valve covers) with 25k miles - 200
both above(currently assembled) - 1600
nitrous:
wet nitrous kit, pieced together. just add wiring/switches and bottle brackets of your choice. - 300
http://images1.snapfish.com/232323232fp::9>nu=3396>872>964>WSNRCG=3455;49447335nu0mrj
10-lb nitrous bottles, have 2 extra. both need paint - 120 each.
Dynotune Nitrous 2-stage TPS/window switch - 80
http://www.dynotunenitrous.com/store/scripts/prodView.asp?idProduct=194
Autometer Cobalt electric nitrous pressure gauge(PN 6174) - 120
bottle heater pads, have 3 - 40 each
auto switch for bottle warmer - 40
fuel:
Glenn's performance 600hp return style fuel system w/ sumped tank. upgradable to higher hp with more pumps. BRAND NEW - 800 obo
http://www.glennsperformance.com/pr...ucts_id=184&osCsid=b69h0hltbov9im61q75ucdtpv0
FORE black fuel rails for 2V/SOHC, new - 150
96-98 cobra upper and lower intake, valve covers, and timing cover. all PC'ed metallic green. need redone. - 250 intake, 80 valve covers, 60 timing cover, 350 for all
dallas mustang speedcal - 60
intake:
JLT RAI kit for Mach 1 - 140
stock mach intake tube and airbox - 50
JLT heatshield for mach(has shaker inlet opening) - 30
JLT heatshield for regular 96-04 - 20
brakes/suspension/drivetrain:
Baer Claw front and rear brake systems for 94-04 - 600 obo
http://images1.snapfish.com/232323232fp:;5>nu=3396>872>964>WSNRCG=34485639:7335nu0mrj
http://images1.snapfish.com/232323232fp:;4>nu=3396>872>964>WSNRCG=344;343;:9335nu0mrj
http://images1.snapfish.com/232323232fp::2>nu=3396>872>964>WSNRCG=344;345389335nu0mrj
D&D front suspension for 96-04 modular. like new K and a-arms, new coilover kit - 500
D&D rear coilovers on lakewood 50/50's, used, but in great shape - 250
Maximum Motorsports road race rear lower control arms - 150
Maximum Motorsports rear coilovers on Bilstein coilover-spec shocks - 400
Hotchkis c/c plates for 94-04, PN: 3002 - 180
http://images1.snapfish.com/232323232fp:9:>nu=3396>872>964>WSNRCG=3459<99;58335nu0mrj
eibach sportlines for 94-04 coupe, brand new - 200
FFR tubular upper and lower control arms, decent shape, 12mm - 80
set of box-style upper lower control arms, near new, 12mm - 100
'99 Gt t-45. unknown miles, but drives good. - 350 obo
tri-ax shifter for 3650 - 120
exhaust
stock 97 cobra catback w/ welded-in flow knockoffs, has been cut, will need welding - 60
stock 05-09 mid pipe - 80
96-04 catted 2.5" H-pipe, homemade-ish - 80
96-04 o/r X-pipe, lightly dented - 60
96-04 2.5" o/r X that has had cats welded in, nice - 120
fox-body o/r midpipes, H and X, not the prettiest but worked when pulled. - 40 each
wheels/tires/etc:
set of 5 stock mach wheels in w/ like new 275-40 nitto 555R's and 245-40 Yokohama S-drive's on the front, stock 245/45 GY eagle on the spare. - 550
http://images1.snapfish.com/232323232fp:;5>nu=3396>872>964>WSNRCG=3438;:;359335nu0mrj
http://images1.snapfish.com/232323232fp:;5>nu=3396>872>964>WSNRCG=3438;:<735335nu0mrj
4 18x10 and 2 18x9 black chrome saleens. some have bad peeling, some have light curb rash. - 400
ONE 17x9 silver bullitt, 05+ offset, has usable roller tire mounted on it, otherwise brand new. - 50
http://images1.snapfish.com/232323232fp::3>nu=3396>872>964>WSNRCG=33<9:::9<;335nu0mrj
2x 295-35-18 nitto invos - 250
2x 255-35 BFG KDWS, damn near new - 250
1x 245/40-18 riken raptor, near new - 40
1x 245/45-18 riken raptor, near new - 40
295-35-18 Michelin Pilot Sports, near new/new - 140 each/260 pair
335-30-18 Michelin Pilot Sports, near new/new - 160 each/300 pair
http://images1.snapfish.com/232323232fp:;2>nu=3396>872>964>WSNRCG=3448525;53335nu0mrj
set of aftermarket cobra 'snake' center caps - 30
interior
mach rear seats - 150
misc 99-04 dark charcoal interior pieces from '99 GT, '01 Bullitt, and '03 Mach. carpet, plastics, consoles, etc- ask obo
DAD racing seats on rails, not perfect, but function well. - 200
http://images1.snapfish.com/232323232fp:;2>nu=3396>872>964>WSNRCG=343:76775;335nu0mrj
exterior:
side skirts, missing small piece on passenger side. few scratches/scuffs. usable or good for repaint. - 100
http://images1.snapfish.com/232323232fp:;7>nu=3396>872>964>WSNRCG=343:9:9636335nu0mrj
rear bumper w/ reinforcement brackets and foam, foam has tabs broken off but still usable. - 50
http://images1.snapfish.com/232323232fp:::>nu=3396>872>964>WSNRCG=343:9:7:;8335nu0mrj
rear bumper cover. few scratches/scuffs. usable or good for repaint. - 100
http://images1.snapfish.com/232323232fp::6>nu=3396>872>964>WSNRCG=343:9:768;335nu0mrj
http://images1.snapfish.com/232323232fp::6>nu=3396>872>964>WSNRCG=343:9:7:72335nu0mrj
http://images1.snapfish.com/232323232fp:9;>nu=3396>872>964>WSNRCG=343:9:7669335nu0mrj
trunk lid. spoiler's busted beyond use. will not come with 3rd light or lock cylinder. needs a spot of firberglass work on passenger side. has scratches and scuffs as well. - 50 - pending
http://images1.snapfish.com/232323232fp:;3>nu=3396>872>964>WSNRCG=343:9:5688335nu0mrj
http://images1.snapfish.com/232323232fp::5>nu=3396>872>964>WSNRCG=343:9:649;335nu0mrj
http://images1.snapfish.com/232323232fp::3>nu=3396>872>964>WSNRCG=343:9:6692335nu0mrj
pair of Azure blue mach c-pillars, no glass, one is pretty nice just a couple scratches, other has scuffing/scratches and could use a spot of fiberglass work(cracked) - 100
http://images1.snapfish.com/232323232fp:99>nu=3396>872>964>WSNRCG=343:55325;335nu0mrj
http://images1.snapfish.com/232323232fp::3>nu=3396>872>964>WSNRCG=343:553257335nu0mrj
'99 black trunk lid w/ shaved holes. not done perfect, but a good 5-footer. has hole drilled for battery kill switch- 80
99-04 taillights, pair - 40
smoked 99-04 taillights - 80
smoked 99-04 headlights - 120
electronics:
99 cobra main engine harness - 80
Bullitt engine harness - 80
Bullitt computer - 80
GT comp - 80
have a few misc harnesses laying around - ask
03/04 cobra-specific:
stock 03-04 fuel rails(have 2 sets) - 40 each
intake tube - 30
EGR sensors w/ bracket - 40
lower alternator bracket - 30
http://images1.snapfish.com/232323232fp::2>nu=3396>872>964>WSNRCG=34427767:7335nu0mrj
SCT X-Cal 2's. unlocked, wiped clean, ready to go for your e-mail/custom tuning. - 160
nitrous:
fuel:
intake:
exhaust
wheels/tires/etc:
interior
exterior:
electronics:
GT comp - 80
intake tube - 30
