miscellaneous mustang parts
dino
waller, tx
'03 Mach 1 automatic drivetrain. less than 10k miles. motor, trans, comp, harness. complete swap. - $2,999 OBO
http://images1.snapfish.com/232323232fp:;3>nu=3396>872>964>WSNRCG=343:3;3:8:335nu0mrj
Aluminator shortblock(lower compression version), needs one piston replaced(damaged ring land) - 1500
complete Windsor PI heads(loaded w/ cams/valve train, w/ valve covers) with 25k miles - 200
both above(currently assembled) - 1600
nitrous:
wet nitrous kit, pieced together. just add wiring/switches and bottle brackets of your choice. - 300
http://images1.snapfish.com/232323232fp::9>nu=3396>872>964>WSNRCG=3455;49447335nu0mrj
10-lb nitrous bottles, have 2 extra. both need paint - 120 each.
Dynotune Nitrous 2-stage TPS/window switch - 80
http://www.dynotunenitrous.com/store/scripts/prodView.asp?idProduct=194
Autometer Cobalt electric nitrous pressure gauge(PN 6174) - 120
bottle heater pads, have 3 - 40 each
auto switch for bottle warmer - 40
fuel:
Glenn's performance 600hp return style fuel system w/ sumped tank. upgradable to higher hp with more pumps. BRAND NEW - 800 obo
http://www.glennsperformance.com/pr...ucts_id=184&osCsid=b69h0hltbov9im61q75ucdtpv0
FORE black fuel rails for 2V/SOHC, new - 150
96-98 cobra upper and lower intake, valve covers, and timing cover. all PC'ed metallic green. need redone. - 250 intake, 80 valve covers, 60 timing cover, 350 for all
dallas mustang speedcal - 60
intake:
JLT RAI kit for Mach 1 - 140
stock mach intake tube and airbox - 50
JLT heatshield for mach(has shaker inlet opening) - 30
JLT heatshield for regular 96-04 - 20
brakes/suspension/drivetrain:
Baer Claw front and rear brake systems for 94-04 - 600 obo
http://images1.snapfish.com/232323232fp:;5>nu=3396>872>964>WSNRCG=34485639:7335nu0mrj
http://images1.snapfish.com/232323232fp:;4>nu=3396>872>964>WSNRCG=344;343;:9335nu0mrj
http://images1.snapfish.com/232323232fp::2>nu=3396>872>964>WSNRCG=344;345389335nu0mrj
D&D front suspension for 96-04 modular. like new K and a-arms, new coilover kit - 500
D&D rear coilovers on lakewood 50/50's, used, but in great shape - 250
Maximum Motorsports road race rear lower control arms - 150
Maximum Motorsports rear coilovers on Bilstein coilover-spec shocks - 400
Hotchkis c/c plates for 94-04, PN: 3002 - 180
http://images1.snapfish.com/232323232fp:9:>nu=3396>872>964>WSNRCG=3459<99;58335nu0mrj
eibach sportlines for 94-04 coupe, brand new - 200
FFR tubular upper and lower control arms, decent shape, 12mm - 80
set of box-style upper lower control arms, near new, 12mm - 100
'99 Gt t-45. unknown miles, but drives good. - 350 obo
tri-ax shifter for 3650 - 120
exhaust
stock 97 cobra catback w/ welded-in flow knockoffs, has been cut, will need welding - 60
stock 05-09 mid pipe - 80
96-04 catted 2.5" H-pipe, homemade-ish - 80
96-04 o/r X-pipe, lightly dented - 60
96-04 2.5" o/r X that has had cats welded in, nice - 120
fox-body o/r midpipes, H and X, not the prettiest but worked when pulled. - 40 each
wheels/tires/etc:
set of 5 stock mach wheels in w/ like new 275-40 nitto 555R's and 245-40 Yokohama S-drive's on the front, stock 245/45 GY eagle on the spare. - 550
http://images1.snapfish.com/232323232fp:;5>nu=3396>872>964>WSNRCG=3438;:;359335nu0mrj
http://images1.snapfish.com/232323232fp:;5>nu=3396>872>964>WSNRCG=3438;:<735335nu0mrj
4 18x10 and 2 18x9 black chrome saleens. some have bad peeling, some have light curb rash. - 400
ONE 17x9 silver bullitt, 05+ offset, has usable roller tire mounted on it, otherwise brand new. - 50
http://images1.snapfish.com/232323232fp::3>nu=3396>872>964>WSNRCG=33<9:::9<;335nu0mrj
2x 295-35-18 nitto invos - 250
2x 255-35 BFG KDWS, damn near new - 250
1x 245/40-18 riken raptor, near new - 40
1x 245/45-18 riken raptor, near new - 40
295-35-18 Michelin Pilot Sports, near new/new - 140 each/260 pair
335-30-18 Michelin Pilot Sports, near new/new - 160 each/300 pair
http://images1.snapfish.com/232323232fp:;2>nu=3396>872>964>WSNRCG=3448525;53335nu0mrj
set of aftermarket cobra 'snake' center caps - 30
interior
mach rear seats - 150
misc 99-04 dark charcoal interior pieces from '99 GT, '01 Bullitt, and '03 Mach. carpet, plastics, consoles, etc- ask obo
DAD racing seats on rails, not perfect, but function well. - 200
http://images1.snapfish.com/232323232fp:;2>nu=3396>872>964>WSNRCG=343:76775;335nu0mrj
exterior:
side skirts, missing small piece on passenger side. few scratches/scuffs. usable or good for repaint. - 100
http://images1.snapfish.com/232323232fp:;7>nu=3396>872>964>WSNRCG=343:9:9636335nu0mrj
rear bumper w/ reinforcement brackets and foam, foam has tabs broken off but still usable. - 50
http://images1.snapfish.com/232323232fp:::>nu=3396>872>964>WSNRCG=343:9:7:;8335nu0mrj
rear bumper cover. few scratches/scuffs. usable or good for repaint. - 100
http://images1.snapfish.com/232323232fp::6>nu=3396>872>964>WSNRCG=343:9:768;335nu0mrj
http://images1.snapfish.com/232323232fp::6>nu=3396>872>964>WSNRCG=343:9:7:72335nu0mrj
http://images1.snapfish.com/232323232fp:9;>nu=3396>872>964>WSNRCG=343:9:7669335nu0mrj
trunk lid. spoiler's busted beyond use. will not come with 3rd light or lock cylinder. needs a spot of firberglass work on passenger side. has scratches and scuffs as well. - 50 - pending
http://images1.snapfish.com/232323232fp:;3>nu=3396>872>964>WSNRCG=343:9:5688335nu0mrj
http://images1.snapfish.com/232323232fp::5>nu=3396>872>964>WSNRCG=343:9:649;335nu0mrj
http://images1.snapfish.com/232323232fp::3>nu=3396>872>964>WSNRCG=343:9:6692335nu0mrj
pair of Azure blue mach c-pillars, no glass, one is pretty nice just a couple scratches, other has scuffing/scratches and could use a spot of fiberglass work(cracked) - 100
http://images1.snapfish.com/232323232fp:99>nu=3396>872>964>WSNRCG=343:55325;335nu0mrj
http://images1.snapfish.com/232323232fp::3>nu=3396>872>964>WSNRCG=343:553257335nu0mrj
'99 black trunk lid w/ shaved holes. not done perfect, but a good 5-footer. has hole drilled for battery kill switch- 80
99-04 taillights, pair - 40
smoked 99-04 taillights - 80
smoked 99-04 headlights - 120
electronics:
99 cobra main engine harness - 80
Bullitt engine harness - 80
Bullitt computer - 80
GT comp - 80
have a few misc harnesses laying around - ask
03/04 cobra-specific:
stock 03-04 fuel rails(have 2 sets) - 40 each
intake tube - 30
EGR sensors w/ bracket - 40
lower alternator bracket - 30
http://images1.snapfish.com/232323232fp::2>nu=3396>872>964>WSNRCG=34427767:7335nu0mrj
SCT X-Cal 2's. unlocked, wiped clean, ready to go for your e-mail/custom tuning. - 160
jbozz601
Meridian, MS
Still got the 335/30/18s? Interested..
And is it a pair or just one.?
bolivianpimp
Spring ,TX
What is the diameter of the JLT heatshield? I have a cl racer 95mm intake and my heatshield is broken.
dino
waller, tx
Location?
just NW of houston, tx.
Dino you still have the 18" tires?
still have all listed.
i've got a few of them, 5 i think.
it's the heatshield that comes with a 96-04 RAI kit, not sure the dimensions.
What year and strategy code is the BULLITT computer?
'01. sorry, shoulda clarified, but i don't deal with s197 stuff hardly.
size and pics of the centercaps
standard 2.5"(have been in stock bullitts, 03 cobras, and mach wheels since i've owned them. lol.)
dino
waller, tx
that is up to you. i wouldn't run them on less than a 10". as far as car fitment, i do not have much experience with s197 tire fitment.
YellowRoush
Houston,Tx
what tranny is this? is this the 00-04 5 speed? or the 05+ five speed?
