classix_stang289
Im using the M-1012-G from ford racing. they are open ended lugs.
How much do they run you?
And what do you mean spline drive?
i actually think it doesnt look that bad, this mod could be called ghost lugs.
you ever see splines on an axle or input shaft and so on? thats kinda what the lug nut surface looks like instead of your traditional 6 point surface. spline drives usually comes with the special socket you would need
i got my lug nuts from poweredbyford.com and they were like 5bucks for a pack of 5. they are part number M-1012-G for mine
check them out they just got another shipment in
As promised
Oh, I know what a splined lug is, I thought you had splined studs.
$5 for longer studs is all?
$5 for studs? no way. ARP's are like $70 per wheel iirc
you need black lug nuts!
You can get them for $105 for a set of 10 studs shipped from here http://www.allensfasteners.com/detail.asp?Product_ID=ARP-100-7723
The chrome lugs dont look bad for joedls's wheel but a black lug would hide that better which is what I would probably go with since idk how much mine would stick on with saleens
How much longer are they over stock?
http://s197forum.com/forum/showthread.php?t=60936&highlight=arp+studs
you can learn a lot by searching............
making a point Kuro.
give a boy a fish feed him for a day..............teach a man to fish and feed him for life.
Which lug nuts are you using? I always wondered if open lug nuts would fit in the Konig wheels since the spline lugs fit well into the wheel.
