05\06 engine wiring harness MT
whitmanink
denver pa
i need a 05\06 gt engine wiring harness for a manual trans ,, i cannot find any for the life of me , only thing i can find is some aftermarket one for almost $1000,
anyone point me into some leads or the right direction?
Hamilton, ON, Canada
Good luck with your search as they're getting super hard to find. BTW, you can convert an automatic harness to work with a standard, so you should be searching for both.
3nigma
Hitting up a junk yard is probably your best bet aside from building one.
jlmotox
Manual swap? I just reused my auto harness and added a couple wires, not hard…
Ryan Payne
hey man im currently in the process of manual swaping my car i have everything done and i connected the two wires that are supposed to bypass the nuteral saftey switch but the starter is still not working, did you have a similar issue?
Caden
Do you have steps on how to convert an automatic harness to work? Or a list of connectors one would need?
