amustangrocks
it might be mostly novelty, but i had to have one.
install wasnt too bad at all. my first look under the car i was looking at the side of the trans thinking no way. but look a little further back, its pretty open where the shifter actually is.
follow the instructions. remove the upper and lower console, put the car in D ( with the e-brake on) i just turned the key off as much as i could and shut the door to stop the chiming.
now under the car, the linkage clip, you can see where i put the screw driver, if you press on the inside towards the drive shaft you will feel it move, then with your other hand push the outside of that clip up till it till it stops. it will be flushed out(flat across the bottom, maybe 3/8" up) then gently pry the bracket off.
i used the same screw driver to press in the 2 white dots on the frame bracket, while trying to push the cable out of the square steel hole in the bracket.( little bit of a challenge)
in side the car, unplug the connector to the shifter and 2 bolts, 2 nuts, instal the streetfighter, connect the linkage, console, testdrive of course.
not that anyone is like me, but the first thing i did was shift the new shifter( just out of the box) up into park, the shifter locks there and wont move to go back to d for the install. once you bolt in the tci, you can hook the wires up, turn on the key and you can shift it to d, and finish the linkage install.
shift reaction of the trans is the same as shifting the oem, but there is no chance to hit anything more than 1 gear at a time. the od button is nice, as is the indicator light. the handle is threaded on so it can be changed too. ive had it for a while now, its bad to the bone. i get alot more fun out of the torque of the lower gears. its a real nice unit, got it from am on sale.
heres a real good install instruction
http://www.streetlegaltv.com/forum/tci-streetfighter-ratchet-shifter-5r55s-2454.html
heres as couple pics of mine
and the boot is not horrible, it just has a stitch line around the top of the boot that doesnt sit right on mine.
