05 gt to 09 gt
Discussion in 'Hardcore Tech=*MOTOR SWAPS*' started by Smeaglly, May 17, 2017.
  1. Smeaglly
    Smeaglly Junior Member
    29
    So I had an 05 gt stock motor that was blown and swapped it for a stock 09 gt motor, and ever since the swap the car has been idling rough and lagging/hesitating upon acceleration, i have replaced the fuel filter, fuel pump, new battery, newer spark plugs, cleaned the maf, cleaned throttle body, cleaned motion plates, checked fuel injectors, replaced broken catts that were blocking o2 sensors, oil change, transmission fluid change. And now come to find out after driving the car barely 25-maybe 50miles that I have no oil, does anyone know how any of this could happen?
  2. weather man
    weather man Persistance Is A Bitch S197 Team Member
    13,164
    31
    Who did the engine swap?
  3. RocketcarX
    RocketcarX 95% of my weight is fuel
    2,612
    150
    You would know if the engine oil was blowing out the tail pipe, sounds more like someone forgot to put oil back in it.
    I believe that is a wiring change due to the ignition coils being an updated design, but I may be miss-remembering that info.
    Otherwise we need a run down of the active codes and a compression test.
  4. Smeaglly
    29
    Found the problem, we had 2 o2 sensors swapped by accident
  5. RocketcarX
    2,612
    150
    What happened to the engine oil?
  6. 05stroker
    05stroker Never enough power guy!
    13,005
    43
    Are we being punked? LOL
