Well the installation is pretty straightforward. The rear you have to lift the car and support it with jack stands or have it on a lift, whatever you wanna do. I used a jack under the pumpkin to support the axle as I unbolted the shocks. I also unbolted the sway bar as well, this allowed the axle to be lowered, and the springs and shocks removed. I put everything kind of in the middle for settings. The shock adjusts separate from the springs for ride height. You want the shock to have 1/3 of its piston arm down in the shock itself and 2/3 above. This allows for droop travel. You’ll be adjusting all of this later to dial it in where you want it so we continue to the front once all of that is bolted in and set. The front is easy, raise the car and unbolt the top 4 bolts on the strut tower and the two on the knuckle. Remove the front strut and spring assembly and detach the brake lines and sway bar end links. Now this was fun, the sway bar end links I mean. You have to adjust the ride height FIRST before reattaching the sway bar end links as you’ll have to adjust the sway bar end link mount points. I personally just measured the distance on the factory struts from the top hole for the knuckle bolts to the sway bar link mounting hole and copied it to the coilover once I had it all dialed in. With jack stands and a buddy I had it all done in 4 hours and a LOT of that time was me being anal and just taking my time to figure it out. Now I will say this, the camber adjustment looks to be a BITCH. I didn’t fuck with it. I left the settings the way they were, right in the center, for both sides and my eyeball alignment looked pretty good. I didn’t have much toe either with just throwing them on there but I never put it on a alignment rack.
All in all install is pretty easy for your backyard mechanic. Make sure to remove those front sway bar end links COMPLETELY though. I had one flip down on me while I was lowering the car and it bent. They’re cast aluminum. They bent fine but when I tried to massage it back into a straight position it snapped like a twig. $20 factory replacement didn’t hurt me too bad but it was a lesson learned. Dialing in the suspension isn’t too bad but you have to take the wheels off and put em back on. Best thing to do is to get it close, drive it around for 10 minutes on a road with a few bumps and dips, nothing crazy, let it settle the suspension then take measurements with a tape measure of your ground to fender distances and adjust the car according to those measurements. If the left is lets say 29” and the right 28.5” then adjust the left down ½” of threads on the coilover. Go drive it again and check again. Lengthy process but WELL worth it.
I’ve been back on the stock suspension going on 2 weeks now. God I miss these coilovers and if they don’t sell soon I will be throwing them back on. The car feels too boat like without them. Weight transfer sucks ass on stock suspension. I will say the car hooks up better now in a straighline launch but the twisties are damn near scary at high speeds without my coilovers. I had a lot more confidence in my car in turns with the coilovers.
Also, another note, if you don’t already have an upper control arm for a lowered car I suggest you get one. Not NECESSARY but you’ll thank me later. Also LCA relocation brackets aren’t a bad idea either. This is typical lowering a solid axle material. A panhard bar is a nice investment as well, I have a stallion suspension swaybar with Aurora Heim joints in it. Best investment mod wise I’ve made to my car thus far. Really improved the way my rear end handled and felt. No more rear end kick if I hit a bump in a turn.
If this reads funky let me know but I was in a hurry at work typing this out.
Whoever buys these I'll give you my cell phone number and you can call me if you get stuck during the install and I'll walk you through it.
