So in the "Centric and Stop Tech Rotors and Rust" thread, we've determined that you're almost certainly better off from a performance standpoint in going with 18" wheels instead of 19" wheels. And 18" seems to be a fairly popular size from what little reading I've done here.
All other things being equal, that makes sense. The 18" wheels are lighter and have a lower angular mass, and the same thing is almost certainly true for the wheel and tire combinations.
I'd want to run a square setup, which means using 10" rims with a stock suspension (said suspension to be modified later after I get some seat time).
The problem is that there seem to be many more available tire choices for a 19x10" rim than for an 18x10" one, at least when attempting to keep the overall diameter the same as the stock wheels and tires (255/40/19).
Tire Rack, for instance, shows 43 hits for 285/35/19 tires, 7 for 295/35/19, none for 305/35/19, and 24 for 305/30/19, for a total of 74 options. But it only shows 6 hits for 285/40/18, none for 295/40/19, none for 305/40/19, and 2 for 305/35/18, for a total of only 8 options.
There are a lot more tires for the 19x10" rims than for the 18x10" ones, and as time goes on, I expect to see more for the former than the latter.
As a result, between tire availability and improved caliper clearance, I'm awfully tempted to go with 19x10" rims for my first set of rims/tires.
Thoughts?
Also, would 305mm wide tires fit on 10" rims without rubbing under a mustang with a stock suspension? Or will coilovers be necessary for that to clear? What's the largest width tire that can safely be used for track and autocross duty on 10" rims?
Thoughts?
