grats..then it should run high 12's..Let us know how it goes..
i just talked to chris and he just got his computer stack back from dynojet like a month and a half ago so id say its calibrated correctly
What makes you think yours is calibrated correctly?
Eh, take it to the track and post your numbers and that will show what your car can really do. If you're in the high 13s low 14s, then you know the calibration on that dyno is off. If you hit low 13s high 12s, then congrats, Ford gave you a nice present.
Those numbers are a bit high.
You can make a dyno read basically whatever you want, oldest trick in the crapy performance shop book.
With all that said their are things called factory freaks.
Take your car out to the drag strip there and only there you will find out what your car can do.
