Well i picked up the car on Fri night from Lentech Automotive in Ottawa Ontario.I had the 5 speed manual trans removed & the Lentech terminator installed,3 speed manual valve body,with a non lockup converter,a 12 volt switchable overdrive feature,trans break & B&M ratchet shifter.My findings are as follows:
On the highway in overdrive @ 75 MPH the RPM's are 2400-2500,over a measured distance of 140 miles i got 21 MPG.(My manual got 22 MPG)Remember i have a Kenne Bell 2.6L 10 psi blower.I find the mileage & RPM's to be inline & acceptable.
Noise on the highway is about the same.When cruising in town you can hear the trans pump noise sometimes,it has a constant 200 psi line pressure.
Driving in town having to shift the gears with no clutch takes some getting use to.
When shifting from 1st to 2nd with moderate throttle it sometimes feels like i have been rearended,the trans snaps ya into 2nd & throws the car ahead ( i now understand torque with a new respect) the car responds with a shock to the differential & the rear wants to break loose with the car almost fishtailing to the left (Stock Pirellis in use) air temp was 32F last night.The shift from 2nd to 3rd with moderate throttle is about the same.
I am fearful of the unknown in my car now,fear is a allie like the first run i made in Frank Hawley's Drag school in his door slammer.I ran a 1.2 60' 145 MPH @ 9.3 sec.
Overall the transmission is doing its job very well.
But with any modification there are some minor problems.The cruise control does not work in overdrive,but Lentech are calling SCT on Monday to see if they have a program for this issue,unless you guys know what to do.
The other problem is when i shift from 1-2 with moderate throttle i have belt slip with a squeal & sometimes the car stumbles for a second then takes off when it all catches up.Do you guys have a suggestion for this,what will it be like when i go full throttle at the track,its gonna squeal & slip & fall on its face.
Also why is the belt slip occuring in the first place.
