I have 2 versions available for those looking to swap. These are the same trans setups currently in Ken3030,ULEV1st,WhippleChicks, and my car.
Full manual with trans brake $5300.00+ shipping
Full auto, no trans brake with stand alone trans computer $6350.00+ shipping, included base tune ,t-body mod with tps sensor.This upshifts and downshifts almost like stock!!!
I have a in house trans builder who is building these for me. All warranty issuses will be handled by ST Motorsports. Lead time is approx 1.5 weeks from order date. I also have a discounted shipping rate, so you can compare your rate to mine.
On the drive shaft...you will need to replace the pinion flange, as I dont like to use adapters on the drive shaft.
Includes trans rated for 800 rwhp (6 mo warranty)
deep sump pan
trans mount adapter
lokar dip stick tube
PA Valve body (for manual version)
Super Stock steel driveshaft with solid joints
New pinion flange and nut.
New PI convertor ( you pick stall)
Flex plate (sfi additional)
Flex plate bolts
Bell Housing bolts
Pinion yoke bolts
Any questions please call the shop.
deep sump pan
trans mount adapter
Flex plate bolts
Bell Housing bolts
Pinion yoke bolts
