AMR 19x10 on the front
KatoS197
Addison, TX
Isn't there a thread on this already?
I did my due diligence in searching. Nothing came up with anyone owning this setup.
I read that they used to be offered in a 19x9.5 and there were center cap issues. Just wondering if that's going to be the case with a x10.
Plus an AM Chat guy told me I'd need to run about a 1" spacer on the fronts?
KatoS197
Addison, TX
FINALLY found a post by going through each thread under "square" search and found a guy running 20x10 AMR's with Brembos and no issues. Thank the Lord Almighty.
Gabe
Whippled Coyote
Yes they'll clear Brembos and they'll fit:
No, there isn't a lot of room between the side of the wheel or the side of the tire and the side of the strut or the stabilizer link stud:
That ^^^ is with a 275/40/19 tire
V8 Vol
El Jefe
Cumming, GA
^^ this may be important. I forgot to add I have aftermarket endlinks on my front setup
KatoS197
Addison, TX
Hmmmm well I'm not sure if that changes anything as far as clearance goes. A guy running 20x10 AMRs said he clears no problem.
mavisky
Atlanta, GA
20x10 +48mm AMR's with 285/30-20's clearing stock brembos and stock swaybar end link.
It's tight, but it does clear.
csamsh
OKC
Take a bandsaw to the endlink stud. I had to do it to get my 11's to fit up front.
aestang22
Toledo
Im looking at running a 19x10 with a +45 mm offset in front. anyone know if this will clear with no rubbing?
MustASH
Canada, Qc
Don't want to hijack thread but, anyone run square 18x10 10th Anniversary Cobra Style, and does they clear Brembos ?
I want to get a spare set for lapping, 79$ each on AM...
mavisky
Atlanta, GA
That's 3mm more clearance away from the strut body than I have with my +48mm wheels and there is plenty of room between the wheel and the fender for that 3mm and more.
