don_w
Dyno Numbers - Who Cares?
Here is that thread: http://www.s197forum.com/forum/showthread.php?t=793
Well, that makes me feel a bit better. Chances are it's just a set-up issue, and not defective part as you had. Thanks for all the info.I could hear it at pretty much all speeds (on decel).
I believe that once you setup gears and run them, that you can't fix that whine. It takes a new set with the right lash, pre-load, etc. to get it right.
Mike
