I have the BMR Kmember and non adjustable Aarms on my car and I road race the car. There are some measurements you can do the check the squareness of the Kmember position. I take a measurement of the wheel base by putting tape measure on the back edge of the rear wheel rim and measure to the rear edge of the front wheel rim on both sides. I also measure diagonally from the grease sert on the bottom of the front Aarm to the grease sert of the rear LCA on the opposite side of the car. You can loosen the Kmember bolts and the motor mount bolts and use a ratchet straps (find the appropriate spots) to pull the Kmember into position to get it close to square. I don't have to support the engine this way as long as the bolts are loose it will move around a little and the straps will hold it in place while you tighten it bad up. You can also do the same thing with the Aarms. Just loosen those two bolts up and use a strap to pull in the direction you need. This can really change the wheel base an bit too. It is a bit of work but I have gotten mine almost dead on square to the rear axle.
I forgot to mention I have a drive on 4 post lift so that does make it easier. You could do it also on some homemade 2x10 ramps under all for tires though.
good luck!
Just a side note I recently put the car into wall at Road America at 30+ mph and was very pleased with just how well the BMR parts held up under crash conditions. The only part I needed to replace was the radiator support. It took the brunt of the hits as the frame rails bent and sheared off all in front of the strut tower brace. I am a lot less worried about "lighter" parts on the car now as I know the BMR parts are very strong and well designed.
I will have a rebuild thread soon with pics but I'm working hard every day to get it ready for the next USCA event.
Awesome info and feedback!
Hopefully some people see this - as the few occurrences with cracked or broken parts have surely led people to believe that our parts are only for a "drag car".
Heck - I have seen our competitors even make posts like "if BMR can't get it right, we are not willing to attempt it" - unfortunately.
