I'm going to assume that you're blowing the BAP fuse, and not the FDPM fuse.
Fuses blowing is caused by two things, a short or an overload. Which one you do first is up to you, but finding a short is easier than finding an overload.
Short: Check the *entire* length your wiring after the fuse for an intermittent short. I've found that you have to physically run your hand along the wire and feel for any cuts and chaffing damage. Pay attention to areas where parts of the car may come in special contact with the wire. Also look for any melted points, or bad wire junctions / connections while you're at it.
Overload: The overload is originating from either your BAP or from the fuel pump(s).
Questions First: Where do you have the dial set? If you turn it to the lowest voltage setting, does the fuse still blow? At what level of driving does the fuse blow?
If you remove the BAP from the circuit, does the FDPM fuse pop? If yes, look at fuel pump(s), as well as their connections.
If you remove the BAP from the circuit, does everything work fine (except for not having the BAP...)? If yes, look at the BAP.
To check the BAP you need a way to monitor current exceeding 30amps, or just remove it and send back to KB and have it checked.
