Boss rod torque specs.
Slick4.6
Central NJ
Does anybody know the torque specs on the boss connecting rods? I can find the for the for the coyote but wasn’t sure if it’s the same for the boss. Also are the rod bolts reusable or should the be replaced after each use and run time.
eighty6gt
Rod bolts aren't reusable, are available from ford if you're checking clearances.
Same spec as for the coyote - tty
