Axes-Of-Evil
- Joined
- Sep 1, 2009
- Posts
- 113
- Reaction score
- 0
Hi guys, I ran into a bit of a unique situation (I think) when I switched out my brakes.
So, not entirely sure if it will help but here is the (extensive) full back story:
I was getting prepared for my first time going out on an open track (Streets of Willow Springs) and had stock brakes, pads, and fluid. I knew I needed different ones for the track so I ordered some carbotech xp10 and xp8's along with brand new rotors, I also picked up 3 bottles of Motul RBF600. The car also used to be a v6 so I also ordered new caliper brackets to fit the new GT sized front rotors. I lifted the car up, took off the old rotors, pads, and caliper brackets then proceeded to put on the new ones with compressing the rear piston for the ebrake. We then bled the brakes. We started at the back right, then back left, front right, then front left and kept cycling around them until we saw nothing but clean fluid coming out of the brakes. We used up all 3 bottles to make sure it was a good solid flush. During the bleeding process we didn't see any air bubbles coming out of the lines and we would open the zerks as I pressed on the pedal, then close them before I released it to ensure no air got back into the lines. If it did in that process I would presume I would see bubbles coming out on the subsequent pushes but didn't see any, just some really dirty fluid at the start of the process. Also, we made sure the reservoir stayed above the mid line and never sucked air in that way.
After putting everything back together etc. We turned the car on and the pedal went to the floor (I expected that because we compressed all the brakes and obviously they need to get back to where they were pushing up against the rotors at a regular stroke. However, this is when we noticed the problem. After doing a few pumps the pedal gave the feeling that it's had since. It gives a little bit of feedback and bite in the first inch of travel, then it just goes dead and pretty much goes all the way down to the bottom until the last two or three inches and it starts to give some pressure again. It's really weird. I expected less feed back with track brakes but not a dead pedal for most of the travel. When the car is off, after a couple of pumps it goes back to a normal pressure feel but when teh car is turned on it gives the weird travel with little to no feedback. It's also been like this for two weeks now (also a DD) so any air in the lines should have at least traveled around. I had a buddy drive it who has tracked his mustang and done multiple brake swaps and he said it sounds like the brake booster isn't working when the car is on. Any ideas?
TLDR:
Did a brake swap, 99% positive no air in the lines, pedal feels fine after one or two pumps when the car is off but when the car is on there's feedback for the first inch or two then it goes dead until the last inch or two down on the floor. Friend said it sounds like a potentially dead brake booster, but I don't know why the brake booster would just die out of nowhere. Brakes were fully functional with no sign of issues prior to the swap. Suggestions or experience with this issue?
TLDR:
