demarcom
Seems like bad news... I lent out my trq wrench and now that it's returned I was going to change out the belt for a new one. Well... while i was at it I figured it would check to trq of the water pump pulley bolts and a few others. The h20 pump seemed rather loose and wasnt htting the 20lbs of trq easily... so the brainiac I am I tried it on the idler pulley to see if the bolts were just loose. Well, it seems my trq wrench came back busted and would not click... I overtorqued the idler bolt and when I removed it the boss was broken off.
i was able to get the boss back on the cover and was able to re-bolt up the idler. it's the idler above the tensioner and it really doesnt have much belt tension on it.. it's mostly a smooth guide pulley..
So.... everyone here always has good advice... Since the idler re-torqed to 20lbs with my other wrench, do you think it's OK? or do I have to change the cover??? What a dumbass problem the may cost me some big dollars and time....
If I do have the change the cover. how involved is that??
