Broken Idler pulley bolt Help!!
johns197
Hello everyone, new to the forums.
i just recently purchased a 2008 gt, been replacing old parts and just performing overall maintenance, went to change idler pulley i had a bad whine. While i was removing the idler pulley bolt it snapped, was able to drill it out no big deal, went to hardware store got a new bolt, this time steel bolt, bad idea... well i almost had everything in and tight then bolt head snapped.. now i have been trying to drill it out for 2 days, no success. not enough room for my more powerful dewalt drill. not sure what to do? here are some pictures.
86GT351
Sunny South Florida
If you can't get a good angle and a good bit in there you will be replacing the timing cover
johns197
im gonna try to remove fan shroud so i can get better angle, hoping to not have to replace timing cover very $$$
johns197
okay, so today i removed cooling fan from radiator and was able to drill out bolt, but now threads are ruined gonna have to use tap and die kit...
Marble
Shasta county CA
Glad you got it out!
Next time try a tap to remove it.
And also when you rethread the hole you need to make sure its square. If it isn't, your pulley will be off and cause issues.
07 Boss
Sin City
My query is how hard were you wrenching on that bolt/s to break them? I've put mine on dozens of times but I never remember ever torquing it that hard.
johns197
What do you mean by square?
johns197
Not hard at all, honestly it was just old and couldn’t take it i guess
johns197
Update ** finally got new threads tapped.. started right up running like a champ no issues.
