I use steeda adjustable front strut mounts. They allow for +/- 1 deg of camber. That's +/- 1 deg on top off what you already have. No caster adjustment. The car has loads of caster as is. ( 7 degs). The steeda HD adjustable front strut uses a 5/8" bearing. The Vorshlag version uses a 3/4" bearing.
My camber is maxed out at - 1.75 degs..... and both fronts are slightly toed out. Handling is superb. Zero inside wear on the fronts. Staggered setup. Can't rotate the fronts side to side either. Some neg camber improves the handling quite a bit.
