I had a JLT catch can running with my Whipple back when It was non-intercooled and only ~6 lbs of boost. When I upgraded to the intercooled HO setup I notice quite a bit of oil in the manifold so I removed the JLT and went to K&N breathers on each valve cover. That was stinky sometimes and some oil was getting on my valve covers so recently I ordered the little upgrade filter/screen from JLT and put that in and hooked the catch can back up. Well a couple of times when I have gotten into boost since hooking the catch back up I have noticed excessive exhaust smoke. I am pretty sure oil is getting past the can so I have ordered a CFM breather kit and maybe that will help. I will report after I get it in and installed.
My first catch can I started out with was in fact the JLT.. Despite the upgraded filter/screen, oil was still getting past the PCV connectors, into the intake manifold and also coating my throttle body and air intake tube..
In addition, even when driving under normal driving/non boosted conditions, oil still got past the JLT anyhow.. Although I personally have nothing against the JLT can, it just didn't work out for my particular application..
So I upgraded to the Bob's autosports catch can which IMHO has a much better design over the JLT that includes an upper and lower chamber separated by both stainless steel filter mesh material and SS filter ring..
It also includes a larger diameter 5/8 inch hose that helps condense crankcase oil more efficiently and also discovered the longer run of hose between the catch can and intake manifold has made a difference as well..
After running the Bob's can for 6 months, I haven't noticed any oil getting past the PCV connectors at the intake manifold nor on the throttle body and air intake tube.. Therefore it does appear the Bob's can is indeed working and doing it's job very well..
As for my reason for adding the CFM breather.. I wanted to find a solution for venting the crankcase when under WOT/boosted conditions, but also be fully compatible with the factory PCV system under non-boosted, normal driving conditions as well..
So rather than add valve cover breathers that require disabling the factory PCV system, I decided the CFM breather would provide the best option for my particular application, at least in theory anyhow..
At any rate, I would highly recommend using the CFM breather with a catch can that includes the design features I posted.. If interested, I've provided links for the top 2 catch cans to check out..
In the meantime, I'll be looking forward to your report on how well the CFM breather is working out
http://shop.bobsautosports.com/2011-14-50-Driver-side-oil-separator-2011-14-50-Driverside.htm
http://shop.bobsautosports.com/2011-14-50-passenger-side-oil-separator-2011-50-oil-separator.htm
http://www.uprproducts.com/mustang-billet-plug-n-play-catch-can-separator-firewall-11-sc.html
