Changed brakes, now I have a TPMS code.
GT-Bill
I changed my factory brakes to a set of 4 wheel Powerstop rotors and pads. I also painted the calipers while everything was apart. After putting it all back together I have a Tire pressure monitor fault on my dash. Not just the yellow light but it actually says Tire pressure monitor fault. Did I move the wheels to far away from the car or did I spray over something I shouldn't have. Any help would be appreciated before I go to the dealer. Thanks, Bill
BadHabit2Break
Houston, TX
probably need to resync the sensors, which means you will need the little tool to do it.
Maybe you could go by a Discount Tire and have them resync them.
mr. anderson
Moore, OK
have you driven around with the tires back on? I drive to the track and back with my slicks all the time and get a fault eventially (usually after 15 miles). when I put the daily driver rims and tires back on the fault clears once the tires have been put back on. sometimes it takes like a mile for it to clear.
86GT351
Sunny South Florida
Are your wheels all the same size? Did you put them all back to the same location?
GT-Bill
Back the same way.
We did the car one side at a time and the wheels were never away from that particular part of the car. I have put about 30 miles on it and it still says it. Bill
ddd4114
Columbus, OH
I know this is a silly question, but.... have you checked the tire pressures?
Since the sending unit stays with the wheel, I don't see how changing your brakes would be a problem unless you accidentally dropped the wheel on something sharp. Mine always sync within a few dozen miles at the most. I've also found that the wheels will stay synced with the car as long as they stay within 10-15 feet of it.
