Cooling Fan Issues
tmcolegr
It's All About the Build
Central, FL
Have any of you had issues with your cooling fan not functioning correctly – to be more specific, the low speed fan not working?
I’m not absolutely sure, but I think the low speed fan is not coming on. When the fan finally does come on, it seems to come on at about the same speed (volume of air) as when the A/C is on, which is only the high speed fan. That is what leads me to believe the low speed fan is not working. I do not have an overheating issue nor have I datalogged the fans.
I looked at the wiring schematic for the cooling fans and it seems fairly simple. There are a couple of fuses, low and high speed relays and the fan motor. The relays are controlled by the PCM.
I also know that Ford has changed the part number on the fan/shroud assembly since 2005. The new part number is 7R3Z-8C607-A.
94tbird
4R70W FTMFW
NY/NJ
i have the same issue. i just let it run on high all the time. I wasnt even aware of the issue until Josh and Kevin noticed it. I just set the fan to run on High in the tune at 180 so the low rarely would even be used at all
tmcolegr
Central, FL
If I remember correctly Hawgman had an issue. Perhaps he will chime in.
Sure would like to know why Ford updated the fan.
scramblr
New Braunfels, Texas
I need to look at the tune and see what my fans are set at, probably stock settings. I notice when my temp hits 220*, it drops about 30* real quick. Would there be a problem just having the fan run at 180* all the time?
Sorry for the hijack tmcolegr.
Hawgman
THE fucking bad guy
Texas
Nope, never had (or at least never noticed) a cooling fan issue.
94tbird
4R70W FTMFW
NY/NJ
cool ill look at it
got a part number by any chance?
and it was post 11, not 18
ChevyKiller
Preferred Internet Drink
I just wired mine to be on high all the time when the key is turned.
Too many other things to worry about to add the fans to the list. I just made it a no brainer.
don_w
Dyno Numbers - Who Cares?
San Diego, CA
I asked Adam to do the same thing on my tunes this time also. I can't see any downside by having my fan run whenever the engine is running.
2k05gt
Manassas, VA
any write up on how to do this? ny low speed fan relay fried and would not allow the high speed to kick on, unless I turned on the AC so I replacd the relay and all is ok... but would like to have a switch to operate the high speed fan.
don_w
San Diego, CA
If you just want a manual switch, you could do it like I did. Run a wire from the relay in the fuse box to one side of a switch, and just ground the other side of the switch.
scramblr
Thanks Don. Does the switch work with the key off? And I would assume it has not impact on the fan being turned on automatically by the PCM while the car is running, right?
don_w
San Diego, CA
Yes, I think so (it's been 9 months since I used it). And no it doesn't.
tmcolegr
Central, FL
Today I found out some interesting information from my local Ford
source. In 2007 Ford introduced a "increased capacity cooling fan" for the
GT 500s. Probably part of the larger front fascia opening, larger radiator
& heat extractor hood package. That same fan was also introduced on the
mid year production 2007 4.6L cars and is now std. equipment on all 4.6L &5.4L S197s. If you order a replacement fan/shroud assembly, the part# is
automatically superseded by the new fan/shroud part#.
I purchased one of these new fan/shroud assemblies for my 2005 GT as the low speed fan failed. The part # is 7R3Z-8C607-A. List price was $375, but with my discount I picked one up for $240. Don't know what difference, if any, the new fan will make on cooling system temps or more importantly AITs, but I thought I would share this information.
MLC40
Naperville, IL
After you get it installed let us know if it lowered your cooling or IAT temps.
TIA
thump_rrr
Montreal Qc,
In Dons' pics the relay with the jumper is the low speed relay. The low speed relay goes through a resistor before going to the fan. If you run too long on low speed you will overheat the resistor and burn it. If you use the jumper on the relay to the left of it it will jump the high speed fan.
scramblr
Good inputs Don and Peter, thank you. I checked my tune today to adjust my fans, but JDM only allows adjustment of Tire Revs and Gear ratio. :hammer: I was hoping I could have my fans turn on at a lower temp.
Don, do you remember how you wired your fans to be on all the time while the car is running? And hopefully explained on a 2nd grade level...like with crayons. :thumb:
don_w
San Diego, CA
In Dons' pics the relay with the jumper is the low speed relay. The low speed relay goes through a resistor before going to the fan. If you run too long on low speed you will overheat the resistor and burn it. If you use the rejumper on the relay to the left of it it will jump the high speed fan.
I didn't know that. Are the two relays the same? Can I just switch there locations in the box?
Ummm... it isn't wired that way at all. If I flip the switch the fan turns on, but with the switch off it is controlled by the tune. I have however, asked Adam to set the tune so that it stays on all the time from now on.
scramblr
Oops, thought it was you, sorry. It was Mark.
How about it Mark, any info on wiring this up?
