I seriously considered these before going with a different model Corbeau. I had tried TMI, but the quality was terrible and, after a couple returns, gave up. The Corbeaus are much higher quality (and more expensive). For me, the driver's side Corbeau came with some thread loose, and I didn't notice until a couple weeks in. When I called Corbeau and sent them a picture, they sent out a replacement THAT DAY and paid to ship the old one back. Great service.
Just a warning, unless you want to stare at an airbag warning light, you'll have some work in changing out the stock seats. If you have side airbags now, you'll have to put a resistor on the plug so that the car continues to think the side airbags are there. You'll also have to locate the driver's position sensor somewhere on the new seat rail and plug it in.
Lastly, you'll have to move the passenger side bladder from your OEM seat to the Corbeau. Even then, it won't perform EXACTLY as stock because the bladder will read a different amount of pressure when in the Corbeau. But, it functions well enough, I suppose. On the OEM seat, the car turns off the passenger side when the weight in the seat is between 5 and 40 lbs. But, with the Corbeau, my 100 lb daughter will occasionally trigger the system off. Only happened once or twice though.
Lots of YouTube videos on the above install. Good luck.
